Carvin DCA 800, only NPN? Carvin DCA 800, only NPN? - diyAudio
Old 23rd October 2002, 10:10 PM   #1
cm961 is offline cm961  Canada
cm961's Avatar
Question Carvin DCA 800, only NPN?
Hey guys,
I just bought a non-working Carvin DCA 800 from ebay. Anyways, its a really neat amp. One channel has like no gain, pretty much what goes in comes out, and the other channel blows the fuse. I measured the resistance between the +ve supply and ground on the amp channel and it was only 30 ohms or so, easy to see why the fuse blows.
I'm getting somewhere with these boards, but I have a big question. I'm familiar with class A, class B, or at least I like to think so. Now these amp channels each use 6 MJ15003 transistors per channel... That is, they're all NPN. So does this mean the amplifier doesn't use a complementary pair?!? Isn't that strange? Can someone point me to some schematics of amps using non-complementary pairs so I can inspect them.
Any help would be great guys!
Pete
Old 23rd October 2002, 11:08 PM   #2
cm961's Avatar
Hey again,
I just wanted to add a few things. I was looking in Randy Slone's book (High power audio amplifier construction manual) (my bible). And out of list of availible output stages, I'd have to say this must be class A single ended. Is there such thing as class B single ended? I really doubt it since it would only output half the signal! Is there such thing as a push/pull (complementary) stage (of whatever class!) using all the same transistor? I don't think so. Man this is a tough one.
Pete
Old 23rd October 2002, 11:19 PM   #3
ThingyNess is offline ThingyNess  Canada
Send a message via ICQ to ThingyNess
If you have Slone's book - have a look at his diagrams for the BJT Quasi-Complementary output stage.
Your OPS most likely has a PNP driving an NPN (Complementary feedback pair) and an NPN driving an NPN (Emitter follower, full darlington connection) on the opposite rail.
It is indeed possible to have a push-pull class B output stage with only NPN transistors.
Consider the fact that tubes only come in "N" type devices, and they've had push-pull class B tube output stages since before I was alive.
Old 23rd October 2002, 11:27 PM   #4
cm961's Avatar
Ok I hate to be a mega poster but...
I just read about the Quasi-complmentary OPS. This appears to be a class B output stage using NPN transistors only! It requires complementary predriver transistors, and it appears that my amp uses RCA1C13/RCA1C12 for that (although there's also TIP31C and TIP32Cs on the board).
Neat!
Old 24th October 2002, 12:50 AM   #5
djk is offline djk
djk's Avatar
http://www.diyaudio.com/forums/attac...p?postid=71431
If the 100F cap in the feedback loop is open the amplifier will have unity gain.
Old 24th October 2002, 03:34 AM   #6
skaara is offline skaara  Slovenia
Its note necessarily class B it can be class AB.
Carvin DCA 800, only NPN?Hide this!Advertise here!
carvin x-100B engel dela pena Instruments and Amps 4 12th October 2007 12:47 PM
wtb Carvin v3 amplifier gemm012 Swap Meet 1 11th December 2006 03:01 PM
Carvin HT1000 problems rkc7 Solid State 3 20th November 2006 10:27 PM
Carvin V3 Head For Sale badhorsie Swap Meet 0 26th April 2006 03:27 PM
REQ: Schematic for Carvin DCA 800 Bargainhunter Solid State 1 1st March 2005 02:47 AM
Copyright ©1999-2017 diyAudio
