i thought my power transformer smoked. when i plugged it again and opened the cover. after 3 seconds one of the 470uf 63v capacitors emitted smoke. it has leak!
will it be possible to order a capacitor here in the GK site store? if i can get the capacitor here... is it ok if i only change the one with a leak or i have to change all 4 capacitors? and... there's a capacitor with the same values but its a vertical one. but the one on the 800RB head is a horizontal type capacitor. will it be ok if i replace it with a vertical type? i need your help GK guys ASAP! thanks very much!!! |
#2 |
Audio Junkie
If one is bad, the other 3 are almost bad. If it was my amp, i would replace all 4.
#3 |
I agree out replacing all 4, but I'd up the voltage to a 75v cap. The 100w amp section (which the 470/63 are for) runs 60v rails. A cap higher than 63V might survive better.
#4 |
alright...
i've replaced the one that leaked. and i plugged it to see if it works. then again... after 3-5 seconds... the other 3 capacitors smoked! now i dont know whats causing them capacitors to blow and smoke. im afraid if i replace all 4. the other 4 bigger capacitors might get smoked as well. theres no service center here... so i'll probly just have it checked by a good technician. damn... i havent even used the amp yet. thanks very much |
#5 |
bump
#6 |
A few possibilities come to mind:
You reversed the polarity of the cap. Electro's don't survive that. More probably, as the old one died as well, is a broken rectifier diode before the cap. Replace it anyway, as I have found myself in the situation that a perfectly good diode seemed to behave badly under working conditions. /Hugo
| need help with gallien krueger 800rb | dkdeleon | Solid State | 19 | 3rd June 2010 09:27 PM |
| Replacment XFMR for G & K 800RB Bass Amp | david maurer | Solid State | 0 | 29th March 2008 07:40 AM |
| Blown up GK 800rb | mpm32 | Instruments and Amps | 1 | 13th April 2007 09:20 PM |
| gallien krueger 800rb no sound | dkdeleon | Instruments and Amps | 1 | 30th October 2005 06:49 PM |
| Page generated in 0.07510 seconds (74.04% PHP - 25.96% MySQL) with 10 queries |
