does anybody has a nice schema for a soft clipper divice
help is very aprieciated
#2 | |
If it is for Class A I would prefer a LED that lights to warn BEFORE clipping.
lineup |
#3 |
diyAudio Moderator Emeritus
I'm not sure if this is what you look for. This one prevents overloading in the differential pair, by putting 2 diodes back to back from base to base
#4 |
This one works in the VAS. Q107 in conjunction with R110 limits the VAS current.
#5 |
One power amp that has "soft clipping" switch is NAD3020i (suffix i).
This power amp is singleton input stage Q402. In the base of this transistor, there is a cct connected to it via C410. Below C410 is what is called "soft clipping" cct, with switch S801-2 is the "enable/disable" of soft clipping. R462, D802, D804 etc is soft clipping cct. I don't understand how this works as "soft clipping". Anyone knows how does it work as "soft clipping" |
| Tubecad soft-clipping circuit | Dusk | Tubes / Valves | 2 | 15th January 2007 08:52 AM |
| Soft-clipping Circuit/tubecad | Dusk | Tubes / Valves | 0 | 18th September 2006 01:34 AM |
| Soft clipping acceptable? | Jeb-D. | Tubes / Valves | 6 | 17th July 2006 01:34 AM |
| Soft Clipping Schematic | sam9 | Solid State | 7 | 17th December 2003 10:01 PM |
| Page generated in 0.09960 seconds (56.62% PHP - 43.38% MySQL) with 11 queries |
