Old 20th December 2005, 12:49 AM   #1
Audio Junkie
Zero Cool's Avatar
Default Test Lamp as a fuse info???
I have seen many repair shops use a standard household light bulb in place of a fuse for testing unknown devices that might have an internal short. This seems to be a pretty common thing.
AND, some speaker companies use fuses in the crossover circuits as current limiting devices.
Where can i find info on what wattage rating bulbs to use for functions as such??
For example. if i am testing a power amp. is a standard 60 watt bulb sufficient? or is there some rule of thimb to size the bulb by????
If i want to limit current to a speaker driver, how do i calculate the bulb???
Is it a 1:1 ratio??? 60 watt bulb limits current draw to 60 watts or????
Old 20th December 2005, 07:24 AM   #2
djk is online now djk
djk's Avatar
For the majority of class AB amplifiers 100W or less, I recommend a 75W 120V bulb. A high bias, high power amp like a Hafler DH500 will need a 150W 120V bulb.
As regards speaker protection, it is best used on tweeters only. For 1" voice coils the 211-2 automotive dome lamp works best. For compression drivers with nominal 1.75" coils the 1156 automotive back-up lamp works best.
Old 20th December 2005, 11:03 AM   #3
Audio Junkie
Zero Cool's Avatar
Perfect, i will give those a try. just out of curiousity? is there any rhyme or reason to these???
Old 23rd December 2005, 02:09 PM   #4
Audio Junkie
Zero Cool's Avatar
Bump....Anyone???
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Bose 301 Series IV, busted fuse, green dot lamp & tweeter 2 inch kolalabang Multi-Way 4 2nd May 2008 04:30 PM
indoor lighting test with LEDS(pics) + need info on dimmers? JinMTVT Everything Else 28 26th January 2008 11:30 PM
Diy UV exposure unit Lamp info Pleas colin.hepburn2 Parts 7 18th April 2004 07:48 PM
Page generated in 0.08711 seconds (71.19% PHP - 28.81% MySQL) with 10 queries
