Old 18th December 2005, 01:50 PM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Smile 2nd Order Distortion Circuit
Hello
Second order distortion is good and third order distortion is unpleasant.
Now many power amplifiers show more 3rd order distortion, than 2nd.
I do not think this is optimal.
Say for example I have an amp output with
2nd order -80 dB
3rd order -75 dB
I am looking for an Op-amp based circuit for adding 2nd order distortion to correct this problem.
After distortion correction I would get a total output of
2nd order -70 dB
3rd order - 75 dB
And so achieve corresponding improvement in total output.
Such an Op-amp based distortion correction circuit
maybe could be between preamplifier output and power amplifier input.
Is this possible?
I have searched here and the web, but found nothing
Old 18th December 2005, 01:59 PM   #2
pinkmouse's Avatar
To clarify - you want to build an op amp circuit to add 10db of 2nd order distortion to your system???
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 18th December 2005, 02:03 PM   #3
lineup's Avatar
yes
to get the proper relationship between 2nd and 3rd order distortion
and so improve the sound of output
Old 18th December 2005, 02:09 PM   #4
pinkmouse's Avatar
Hmmm.
Wouldn't it make more sense to just build a pre with less 3rd order distortion? The whole idea of adding distortion to what is supposed to be as distortion free reproduction as possible just seems wrong to me. Yes, if you want to use it as a musical effect, but for proper listening? I just don't get it.
Al
Old 18th December 2005, 02:15 PM   #5
MikeB is offline MikeB  Germany
MikeB's Avatar
You could also build a circuit that creates 3rd harmonics with reversed sign (180°shift), so it cancels out when amplifier adds his own 3rd harmonics...
Or, (commercial !) you build a symasym, it has by design ~-85db 2nd harmonic and ~-100db 3rd harmonic...
Mike
Old 18th December 2005, 02:20 PM   #6
pinkmouse's Avatar
Hey Mike, if you don't shut up soon, I'm going to have to build one of your &*&^%^%$ amps, and I haven't got the time!
Al
Old 18th December 2005, 02:23 PM   #7
MikeB's Avatar
Har har ! I couldn't resist...
Mike
Old 18th December 2005, 03:18 PM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hey Al,
Mike's already bitten me! That's the next amp I'll build as soon as I can make the PCB's up.
Then I'm going to try a FET diff pair in it.
-Chris
Old 18th December 2005, 03:20 PM   #9
darkfenriz's Avatar
http://www.diyaudio.com/forums/attac...amp=1089450255
You may add a cap across first op-amp feedback R-D ladder for unconditional stability and use bigger caps in output filter (nF instead of pF, my mistake)
but this is probably not exactly what you search for, more like musical crunch for guitar or so.
Old 18th December 2005, 03:38 PM   #10
Send a message via AIM to sychen0301 Send a message via MSN to sychen0301 Send a message via Yahoo to sychen0301
A single side clip will do. All you need is a R and a D.
New (?) Distortion Circuit thespeakerguy Instruments and Amps 3 8th August 2008 09:07 AM
Distortion analyser circuit steevo Solid State 12 21st July 2008 01:42 AM
Seek AGC circuit with low distortion for subwoofer! GPE Analog Line Level 1 3rd January 2007 09:40 PM
In order to eliminate Cms-based distortion, should Cms be... 454Casull Multi-Way 1 1st January 2007 02:05 AM
What is worst - even or odd order of distortion DarkOne Solid State 18 8th February 2002 12:42 PM
Page generated in 0.09401 seconds (80.58% PHP - 19.42% MySQL) with 10 queries
