Old 17th December 2005, 02:34 PM   #1
GIPIONE is offline GIPIONE  Italy
Default 2sk330 Nf
I am try to found the NF of this fet, but the data sheets of Toshiba ( 2003-03-25) don’t write this important value.
Same of you know it?
Thank
Giampietro
Old 17th December 2005, 02:47 PM   #2
widowmaker's Avatar
Send a message via ICQ to widowmaker
Hm, Toshiba has on their 2SK330 these symbols:
Id @ Ugs=0V : Y: 1.2~3.0 mA, GR: 2.6~6.5 mA, BL: 6~14 mA
Try with another manufacturer...but I think that only Toshiba is a manifacturer of 2SK330
( probably )
or... your JFETs are fake...
Audio Researcher
Daniel Petrov also known as widowmaker
Old 17th December 2005, 02:57 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: 2sk330 Nf
Thank
Giampietro
I do not know if there are different datasheets PDF
and if NF is in any of them
Here is a search 2SK330 at datasheetarchive.com
http://www.datasheetarchive.com/sear...330&sType=part
Old 18th December 2005, 05:27 PM   #4
Default NOISE FIGURE of 2SK330
o.k. thank for the link of data sheets, but I don’t find the noise figure ( NF) of this device.
The NF is very important value if you use this component in audio application , that I want do tha KANEDA line and phono, I don’t find the 2SK33AGR for the input differential stage, and for the Yfss and Ciss I think substitute with the 330 but I don’t know the NF and Is possible a phono with to much noise.
Thank
g.pietro
Old 18th December 2005, 05:35 PM   #5
widowmaker's Avatar
2SK170 is preferable...
NF is 0.5dB (typical)
2SK389, when the input stage is differential...NF is the same.
Audio Researcher
Old 18th December 2005, 06:09 PM   #6
claudio is offline claudio  Italy
claudio's Avatar
is possible to use the 2SK389 in a not differential schematic? I mean, the first transistor for the left channel, the second one for the right channel, being the 389 a double transitor?
Claudio
Old 18th December 2005, 07:26 PM   #7
tvi is offline tvi  Australia
tvi's Avatar
Which Kaneda line & phono are you considering?
I don't recall Mr Kaneda using a 2SK33AGR, maybe your schematic is a bit indistinct and should read 2SK30AGR.
Have a look throught this site (sorry it in Japanese) konton the second button (red) is Kaneda preamps.
Hope this helps
James
Old 18th December 2005, 08:07 PM   #8
widowmaker's Avatar
Claudio
The substrate is common for both transistors.
In your cause it is possible, both JFETs work @ the same voltage.
Just connect the substrate lead (pin 4) @ most negative supply.
But you can't use separate PS for each channel.
Audio Researcher
Old 19th December 2005, 01:28 PM   #9
Default ERROR KANEDA
Sorry is error Kaneda use in differential input stage the 2SK30AGR no 2SK33AGR
Pardon.
gp
Old 19th December 2005, 03:09 PM   #10
Default Yfs not equal
Ok I know the sound and quality of 2SK170 are very sonic, but is necessary pay attention to Yfs are no same
170=22
330=4
30= 1,2
is value typical and is no very important if you use this device in circuit with all feedback ( kaneda for example) where the all gain is determinate by the feed and no by single component.
G.ietro
Page generated in 0.10038 seconds (79.75% PHP - 20.25% MySQL) with 9 queries
