Borbely Audio
Borbely Audio
Old 19th December 2005, 12:54 PM   #11
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Borbely Audio
Default Re: Borbely Audio
Originally posted by biovizier
Anyone tried their kit? Specifically the phono or buffer units?
Erno has his JFET/MOSFET thing and this is implemented to 100% whether this is right or wrong. I like this. All his designs are "approved" by me, nothing weird, good engineering. The only objection I have is possible his handmade pcb layouts. Even a student nowadays handles Eagle or whatever to do real nice looking pcb's. For the prices he is charging I at least would have demanded highest professional pcb's both in looks and in performance. The pcb's he is offering now looks a bit "vintage". I haven't examined the pcb layout itself, how good the are in the electrical sense. I'll believe they are pretty good but I don't know if they reach "Spitzenklasse".
I haven't mentioned the prices: 850 EUR/USD for a kit
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 18 pcb's in interest so far.
Old 19th December 2005, 01:45 PM   #12
Sigurd Ruschkow is offline Sigurd Ruschkow  Sweden
Well,
I think that transformers have a sound of their own, and I am no fan of transformers. If you are, go for the S&B transformers, and dual superbuffers.
I will go for the /420 with the upgrade option, ie Caddock resistors and maybe even BG caps. Teflon PCB of course.
Sigurd
Old 19th December 2005, 01:50 PM   #13
biovizier is offline biovizier  United Kingdom
I assume the 320 would be better than the 420? Did you use the top of the range all fet reg?
Old 19th December 2005, 02:01 PM   #14
The 320 amd the 420 are rather similar. The most dramatic difference is that the 320 uses a MOSFET on the ouptut while the 420 uses JFETs.
The 320 can probably handle lower output level MC pickups.
The 320 is a bit pricey for my taste. I hardly play any LPs but when I do I want a very, very good RIAA amp!
Yes, I use the 254 PS and also have the 319. Nowadays, however, I use Per-Anders RFB02 for rectifying purposes.
http://home.swipnet.se/~w-50719/hifi/rfb02/index.html
used with either soft FREDs or Schottky diodes.
I just ordered another 254 which I will use for another line amp.
Borbely has 10% discount in December!
Sigurd
Old 19th December 2005, 02:18 PM   #15
Panelhead is offline Panelhead
Default Re: Re: Borbely Audio
The circuit boards are not very pretty. Also, single sided. Nice heavy traced, double sided board would be a big improvement.
The 419 was 300.00 USD Delivered.
George
Old 20th December 2005, 02:02 AM   #16
fab is offline fab  Canada
fab's Avatar
Default Re: in EB693/129
Originally posted by john-china
almost in Amp designed by borbely audio , open loop gain is above 85db, open loop frequence is only 2.2khz -3db ,
so i think conflict with prof. Leach
I think you refer to the Servo DC-50.
Erno Borbely more recent designs have also different open loop frequency or gain. For example, the EB-1198/116 ALL-FET line amp has 67db open loop gain (medium open loop gain compared to 85db) with open loop frequency close to 20 KHz! Its open loop THD at 3V rms is 0.095% at 10 KHz.
Borbely AudioHide this!Advertise here!
Borbely Audio EB-420 with PS 309 for sale hueser Swap Meet 0 25th November 2007 04:46 PM
Borbely Audio phono stage biovizier Swap Meet 12 9th February 2007 07:09 AM
borbely audio website Luke Everything Else 6 26th October 2006 03:48 AM
Borbely audio 420 phono stage biovizier Solid State 0 16th May 2006 09:45 AM
Copyright ©1999-2017 diyAudio
