Old 16th December 2005, 04:47 PM   #1
Alcaid is offline Alcaid  Norway
Alcaid's Avatar
Default Want to build balanced mosfet amp
I want to build a mosfet amp and have looked at elliott's P101, but I want a balanced input. Are there any good sounding designs around here with balanced input and an output of around 100-200W RMS@8ohm?
Petter
Old 16th December 2005, 04:51 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Most know are some of Nelson Pass amplifier projects with MOSFET
Old 16th December 2005, 06:08 PM   #3
Bensen is offline Bensen  Belgium
Bensen's Avatar
Hi Alcaid,
I like those designs also the most. There are many people saying, that single differential sounds better than complementary. I must admit I never done a listening test between those two topology's. But enough about that, there are already to much thread focusing on that.
At the moment you can have a look at the next thread, here I'm designing such an amp. I attached a picture of the last version.
(You can't find the full output stage on this picture)
It has about 170Wrms/8Ohm and 260Wrms/4Ohm.
I'm using JFET's as input stage, but this can easily be converted to use BJT's. With BJT's you also won't need the differential VAS.
All the Crescendo amps have also what you are looking for, or the AEM6000, buzquito, Hafler amp's, ...
http://www.diyaudio.com/forums/showt...&postid=788904
Ben
Old 16th December 2005, 06:40 PM   #4
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default Balanced input
Or, you could use a trafo, like Jensen or Lundahl...
Arne K
Ars longa, vita brevis
Old 16th December 2005, 06:42 PM   #5
Alcaid's Avatar
I know about mr. Pass' designs, I'm actually thinking of buildng a XBOSOZ preamp for the mosfet amp.
Originally posted by Bensen
Hi Alcaid,
Ben
Hi, Ben. I've seen your design and it looks interesting. But isn't your input single-ended?
Old 16th December 2005, 06:45 PM   #6
Alcaid's Avatar
Default Re: Balanced input
Arne K
Could do that, but why add another stage in the sound chain when you don't have to? That's the glory of DIY. You can make exacly what you need.
Old 16th December 2005, 07:00 PM   #7
DIY !
Cobra2's Avatar
Arne K
Old 16th December 2005, 07:05 PM   #8
Alcaid's Avatar
Arne K
Actually, I read what you said the first time. No need to repeat.
Old 16th December 2005, 07:35 PM   #9
DIY !
Cobra2's Avatar
Default Sorry for double-post
DIYaudio.com fell out of reach for 10min just as I posted.
With a trafo, you can take away the input-cap...and in my experience, the Jensen sounds better than any cap...
Arne K
Old 16th December 2005, 07:54 PM   #10
Alcaid's Avatar
Default Re: Sorry for double-post
Arne K
No cap is the best cap, indeed.
The trafo is the solution of a problem, but what about avvoiding the problem to begin with? Aren't there any good sounding balanced mosfet amp designs around? I don't want a class A heating oven, I already have heating in my apartment
looking to build my first MOSFET amp diesel_tech Pass Labs 4 20th November 2008 01:14 AM
How to build a simple balanced mono line mixer jandalo Analog Line Level 4 8th November 2008 12:40 PM
Need to build simple MOSFET preamp!!Please help! thomgun_lc Solid State 20 16th November 2005 09:37 PM
Mosfet Citation 12 build questions Rjones5296 Pass Labs 2 17th December 2004 03:53 AM
Page generated in 0.11817 seconds (75.96% PHP - 24.04% MySQL) with 11 queries
