#21 |
I'm planning to use the NE5534 (or replacement) in an MC phono stage hence the desire for low noise.
Eventually, I was planning (funds premitting) that it'll be upgraded to an AD797 or similar with mods where applicable to the circuitry, As was said previously "pin compatible (sort of)" At this point it's more in the prototype "will it work" kind of stage and hence I'm not planning of filling it with ultimate level chips and caps just yet. The very first cheap metalfilm resistors and MKT polyester caps version actually sounds quite well, I was just wondering if the Class-A mod might also improve things. It's a work in progress drew |
#22 | |
difference between 627 and 637: 627: unity gain stable 637: stable in gain =>5 Hope this helps
Christoph STEAL the BEST - INVENT the REST |
#23 | |
Brian:
OPA627 has an internal compensation capacitor for unity gain stability. Given 20 each? You have NICE friends These aren't cheap, thanks to the DI mfrg process. Michael Quote:
#24 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#25 |
diyAudio Moderator Emeritus
Brian,
OPA627 and OPA637 are probably the best you can get at the moment. 2134 you can't compare to these fantastic opamps. OPA637 is faster and has a higher slewrate but is, as mentioned before, not unity gain stable.
It's only audio |
#26 |
I am sure not all will agree, but I have had excellent success with the new AD opamps as replacements in my SCD player![]() I/V stage; Replaced opa2604 with 2*ad8610s with broundog adaptor (gave smoother mids, less grainy highs and deeper bass) Mixamp stage (converting balanced signal to unbalanced) Replaced opa2123 with ad8620 (got rid of upper bass hump and a more linear response) Buffer/Servo stage (one half of dual opamp did both) Replaced ad712 with ad8620 (gave a more dynamic response and greater transparency) I then applied current loading (Biasing into class A) in succession with; 1. 1kOhm r - greater bass articulation 2. 1kohm r with CRD (1mA) - as above, but with smoother mids 3. 100ohm r with CRD/FET (1mA) - as #2, but slightly better 4. 1kohmr with cascoded JFET (1mA then 2mA) - much better than any other option - took a while to break in, but was very linear and articulate with very clean highs... any residual graininess totally eliminated. I have not done a head to head with the opa627, but others at Head-fi and Headwize have carried out extensive comparisons and the majority consider the 8610/8620 to be much better. Check out ppl's posts One thing that comes out of their comparisons is that this is only worth it if the rest of your system is of high enough resolution to distinguish the difference. Good luck with whatever you choose. |
| New class A biasing (with non-switching class AB overflow) | Steven | Solid State | 34 | 24th March 2007 06:40 PM |
| low-biasing or high biasing in Class-AB amps | Workhorse | Solid State | 124 | 18th October 2005 04:45 AM |
| biasing opamps in class a | matjans | Chip Amps | 33 | 19th December 2003 04:05 PM |
| Page generated in 0.13348 seconds (57.80% PHP - 42.20% MySQL) with 10 queries |
