Class A biasing of opamps
Old 23rd October 2002, 10:27 AM   #11
carlmart is offline carlmart  Brazil
Default 5534 vs 711
What function is that NE5534 being used for?
Both chips maybe pin interchangeable, but are quite different beasts. The 5534 is low noise, the 711 is not.
The 5534 is now cheap, but in the past it was not. The 711 was never too expensive, but now it probably costs a bit more. The reason being that now there are several 5534 types, but only Analog makes the 711.
But before wondering whether to force the 5534 into class-A, which will probably warm it a bit, you should wonder if it's up to the task proper to a modern chip in your application.
Carlos
Old 23rd October 2002, 03:56 PM   #12
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Like OPA637 for phonoamps.
It's only audio. Member of the non modular PCB design committee
Old 23rd October 2002, 06:31 PM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally posted by The Saint
Putting an Opamp into class A with a resistor on the o/p to any supply rail was originally shown by Walt Jung of Audio Amateur Magazine fame.
An active current source works great as well.
The concept works and it does make an improvement...
This technique predates Walt Jung. Barry Thornton was using
resistors about 1970, and the Forte preamp (Pass) used
current sources in the early 80's.
Old 23rd October 2002, 07:49 PM   #14
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Default Re: 5534 vs 711
DrewP, what are you going to use this NE5534 for?
I agree with carlmart, look for a modern chip instead.
OPA134 is a good NE5534 replacement and also not so expensive.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 55 pcb's in order. 45 paid.
Old 23rd October 2002, 07:51 PM   #15
hitsware is offline hitsware
Yep....Good 'ol Quintessence .... Do you know whatever happened to Barry ? ..... Mike (who used to work there)
Old 23rd October 2002, 07:51 PM   #16
peranders's Avatar
Nelson, or somebody else: How much improvement do I get with this class A thing, together with a modern chip? Any audiable/measureable difference at all?
Old 23rd October 2002, 08:03 PM   #17
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
Default Re: NE/SE5534 vs AD711
Calmart asks a (the?) very important question.
Another beneficial characteristic of the xx5534 type parts (vs. the AD711) is a beefier output stage. I've used the AD711 for a long time and after listening to it years ago in some of my prototype circuits, I wouldn't use it in line driver applications without a buffer. It's better than the TL07x stuff in this regard, but not by a whole lot. Nowadays, I like the AD711 in DC Servo applications, power supply regulators, music sythesizer modules (oops, that one slipped out), etc....
The AD711 is a pretty good GENERAL PURPOSE BiFET op amp, not among the best choices for high perfrmance audio line amps, IMHO .
What function is that NE5534 being used for? ....
Carlos
Old 23rd October 2002, 08:25 PM   #18
The one and only
Last I heard Barry Thornton was in Arizona, possibly rep-ing
electronics.
Old 23rd October 2002, 08:27 PM   #19
The one and only
Marginal difference at best, but still a cute tweak that
anyone can do.
Old 23rd October 2002, 08:35 PM   #20
BrianGT is offline BrianGT  United States
BrianGT's Avatar
Send a message via AIM to BrianGT
I have a bunch of opa627 and opa637 that a friend gave me (20 of each). Can I use these in place of opa2134 (assuming that I modify the wiring to use two single opamps instead of one double) in my active crossover? Are these opamps much better in terms of sound quality over the opa2134?
I read over the datasheets, but I couldn't find the difference in the two (627 and 637). Anyone know?
Thanks,
Brian
Class A biasing of opampsHide this!Advertise here!
biasing opamps in class a matjans Chip Amps 36 20th February 2013 02:16 PM
New class A biasing (with non-switching class AB overflow) Steven Solid State 34 24th March 2007 06:40 PM
low-biasing or high biasing in Class-AB amps Workhorse Solid State 124 18th October 2005 04:45 AM
