Old 15th December 2005, 10:52 AM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Arrow Mastroianni Single JFET Input Preamp
Attached schematic
shows a JFET preamplifier by Francois Mastroianni.
I would like to try it. Looks like it is very easy to build.
Input is one JFET 2N4392.
Single rail supply 35 Vdc .
Output is a single Class A follower 2N3252 operated at 15 mA.
No global feedback used.
My Questions:
1 - What modern JFET and bipolars should I use for best results?
2 - Any other modifications to improve performance?
3 - How would this preamplifier perform?
4 - What is major benefits of this circuit?
5 - Serious drawbacks?
Old 28th February 2007, 01:34 PM   #2
stoolpigeon's Avatar
Hi lineup,
Sorry I can't answer your questions but I wanted to ask if you have you tried this pre? If not any more thoughts on the design?
Thanks!
Old 3rd June 2007, 11:28 AM   #3
lineup's Avatar
Arrow JFET preamplifier by Francois Mastroianni
Originally posted by stoolpigeon
Hi lineup, Sorry I can't answer your questions, but I wanted to ask if you have you tried this pre? If not, any more thoughts on the design? Thanks!
stoolpig eon,
you are new in http://www.diyaudio.com/
Aren't you?
You will learn plenty of things, if you stay around for some years.
I have been here for more than 5 years, now.
We all have different levels of knowledge in this forum.
One day maybe I will be asking, to those being newbies now, some questions.
And they will know an answer to some issue I may have.
My question above
was more directed
to all our many experienced members
of our board.
Because An original Mastroianni Amplfier design is always something interesting
You can take my word for this, stoolpigeon
... as you, right now, can only have very limited knowhow in this very topic.
lineup
Lineup Audio Labs Ltd.
Europe
lineup
Old 3rd June 2007, 12:43 PM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
guess something like j310 or maybe 2sk170?
Old 3rd June 2007, 07:14 PM   #5
scott wurcer's Avatar
That 330uF non-polarized output cap might set you back a few euro.
2012, our time is running out.
Old 3rd June 2007, 07:53 PM   #6
flg is offline flg  United States
flg's Avatar
The input JFET needs to be 35V or more,maybe 2sk117?... And looks heavily degenerated? Gain might be modest... And while your there, you might think about making that regulator a JFET also... My first question would be, is the C1 necessary, but, after staring at the foreign language caption for a minute, I guess that's covered... No cap bypassing the 2 bias diodes??? A 330uF at the output seems quite large, generally you can get away with a very high quality cap of lower value, say <33uF, when driving 10K or more...
Old 3rd June 2007, 07:54 PM   #7
analog_sa's Avatar
Not that there is any good reason for it being 330uF. Unless you're driving speakers.
Old 3rd June 2007, 08:19 PM   #8
Nordic's Avatar
I tried simming it, and it seems to be unity gain or a little less... 840mv out for 1v in. Looks nice... and I might try it.
He probably meant a non-polar electrolytic, which could be had for little over a dollar.
Old 3rd June 2007, 09:07 PM   #9
lineup's Avatar
Yes, it looks nice Nordic.
I have a bunch of TO-18, metall case, JFETs 2N4092
I don't know if I can use these here?
.... think they are not same type???
What would you use 2N4092 JFETs for??
They are higher currents than normal jfets.
Nordic,
I think you have setup something wrong.
Gain below or around x1 is too low.
Check your input and output caps.
Gain is set by RD/RS in first stage + one output follower stage.
6.2k/1k would give gain like 5-6 for a bipolar input transistor.
For a JFET we get some Vgs dependent loss,
but like 3-4 maybe is a reasonable Gain figure - for JFET....
Two things, i like them both:
1. No global feedback
2. We may need no Input cap. Can put input directly across 100k resistor.
( at least if your source have only like +/- 0.200 Volt DC or less. )
A. JFET should be replaced with something that works good at 3mA
and can take the voltage of like 25-30V, at least
There are many we could have a go at!
B. For follower 2N3252 we should taget at 15 mA transistors.
BC338, BC337, BD135, BD139, BC639 or something like it.
Can be TO-92. But also of course TO-126
C. A lot of bypassing filter caps
and the use of Constant Voltage (=regulator) in input (most probably also 2N2219A)
and Constant Current Source in output (2N2219A)
... should make a fair and good power supply rejection ratio, PSRR
lineup
PS. might put this into my MultiSim for experimenting!
I am a bit busy with other things than Audio, right now
DS.
lineup
Old 3rd June 2007, 09:27 PM   #10
Nordic's Avatar
Think Q1 is another 2n2219? I prepared a pcb file, but dropped a 2n2222 in there, not realy knowing what to put there...
I guess there is so much headroom, you could use lower rails , (with adaptation of resistors to maintain current and bias levels), even if you have to drop the gain. Then you can use lower voltage fets.
I was haveing a mindfart... I had to sim the circuit in two parts... too big for demo.
Jfet input for Aleph 60? Dansk Pass Labs 14 22nd January 2011 01:34 PM
10 Watt Single End, JFET input - Lateral N-MOSFET output lineup Solid State 82 30th July 2009 06:23 PM
single JFET as volume control Leolabs Solid State 1 13th December 2005 03:59 AM
Page generated in 0.15358 seconds (62.97% PHP - 37.03% MySQL) with 11 queries
