Old 8th January 2008, 03:20 PM   #331
widowmaker's Avatar
Send a message via ICQ to widowmaker
coming soon - pdf file of PCB (last version)
for sale:
price for 2 boards (without components)+paper sheet with component location view - 20 EUR (without shipping taxes).
widowmaker@mail.bg
Audio Researcher
Daniel Petrov also known as widowmaker
Old 8th January 2008, 03:49 PM   #332
Electrons are yellow and more is better!
peranders's Avatar
Is it possible to get thermal stability without any emitter resistors at the output stage?
/Per-Anders (my first name) or P-A as my friends call me
Old 8th January 2008, 04:17 PM   #333
widowmaker's Avatar
It is possible, offset is floating approx. +/- 20-30mV
Current source for IRF620 is unstable "upside down", wich compensate instability of diff. input stage...
Carefully look at schematic - there are transistors after shunt regulator 431, and "strong point" for 620 is emmiter of CS for Diff. stage.
I have score of amps, no problems with offset.
Audio Researcher
Old 8th January 2008, 04:50 PM   #334
Did it Himself
richie00boy's Avatar
I think he means stability of bias current, not output DC offset.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 8th January 2008, 05:05 PM   #335
peranders's Avatar
Yes, I mean the stability of the bias current with different temperatures.
Old 9th January 2008, 07:19 AM   #336
widowmaker's Avatar
Bias current for 9610 is higher than necessary (in this case), so unstability is not much important value...
Output transistors ("dumpers") are near class B - approx. 320-350mV Ube (depending on temperature range).
This is a feedforward error correction amp.
Dumpers originally working without idle current.
Audio Researcher
Old 9th March 2008, 11:41 PM   #337
kalmara is offline kalmara  Bulgaria
kalmara's Avatar
Kolega, haresva mi usilvatelq - slushah go v edin priqtel, no iskam samo da otbeleja...na kartinkata za izhodqshtite droseli pishe (0.86 with lack isolation) ... lack na angliiski oznachava lipsa na neshto i edva li horata sa razbrali kakvo se ima vpredvid, spored men po-dobre za lakovata izolaciq e da se izpolzva varnish. S netyrpenie chakame pdf-a na platkata, za da izprobvame i pravotokovata versiq.
Insane HONDA FAN !!! Variable Valve Timing and Lift Electronic Control equals....HIGH ADRENALINE !
Old 11th April 2010, 11:11 AM   #338
tiefbassuebertr's Avatar
This is also an interesting approach (unfortunately only to find only by chance regarded the therm "Death of Gainclone" insted the actually term for this topology), especially for translate into a CSPP topology (Circlotron).
I will study this thread next time.
In this case also this thread could be of interest:
Chip Amp based on the topologies from Yamaha MX-10000 and Quad 405
Here an inspiration for a solution for an enclosure/cabinet
Synergy - LM3875 Gainclone Amplifier (Chip Amp)
Old 12th April 2010, 01:01 AM   #339
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
The GC case is really beautiful, small and funny.
Old 12th April 2010, 07:00 AM   #340
ljm_ljm is offline ljm_ljm  China
CURRENT DUMPING ?
I VERY LIKE。
BUT,MOSFET TO DARLINGTON ,I believe there will be a better force。
Inv Gain Clone with on board PSU anbello Chip Amps 65 7th May 2008 02:32 PM
CD player for Gain Clone falcott Digital Source 5 26th September 2004 07:04 AM
For all Gain Clone fans................. ashok Chip Amps 21 28th June 2004 12:07 AM
What is a Gain Clone exactly? Lars Clausen Chip Amps 33 26th November 2003 06:33 PM
Page generated in 0.12402 seconds (76.19% PHP - 23.81% MySQL) with 11 queries
