about ccs of Leach Amp
Old 15th December 2005, 09:18 AM   #1
john-china is offline john-china
john-china's Avatar
Default about ccs of Leach Amp
Leach Amp v4.5 uses two zener and some resistors as tail of differential input circuit .
i take the tail as ccs , in normal amplifier , tail ( ccs) is consisted of a transisitor and diode or LED
so the question is which one is better?
Maybe i should not be lazy again
Old 15th December 2005, 10:37 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
I would prefer using LED(s) to set the voltage for a CCS transistor.
Like the arrangement you mention.
What I know, LED produces less noise than zenerdiode.
There are also other factors like temperature stability to consider in some applications.
Generally we see zeners used more frequently as current sources in older amplifers.
A third method is to use JFET and a resistor.
This is the most simple way to make a CCS, constant current source.
Another method often used is two bipolar transistors.
One transistor holds constant voltage across the emitter resistor of the other, while limiting base current.
This will give a CCS of Vbe/Re.
Old 15th December 2005, 11:40 AM   #3
jaycee is offline jaycee  United Kingdom
He is using the current through a resistor as the current source, with the zener providing a stable voltage reference so that the current is constant. His page explains why he did not use "active" current sources.
Old 15th December 2005, 12:28 PM   #4
lineup's Avatar
From Leach website:
Diodes D13 through D16 are 20 V Zener diodes which regulate the voltages that set the bias currents in the diff amps. Each zener diode is biased at a current of about 3.3 mA. Although a single zener diode could be used in place of two series diodes, I have found that the error tolerance in the voltage is less with the series connection of 2 diodes. C2 through C5 are ac decoupling capacitors which ensure the bases of Q5 and Q6 are at ac signal ground.
R15 and R16 set the tail bias current in each diff amp to about 3.25 mA. This current and resistors R7 through R10 set the differential tansconductance gain of the diff amps at about 1.6 mA/V.
- The diff amps use resistive tail current bias circuits.
- Not only do these generate less noise than active current sources,
but they provide a smooth amplifier turn-on that is free of thumps.
He has thought about alternatives but found this to best solution
mainly for 2 reasons.
Old 16th December 2005, 01:23 AM   #5
amplifierguru is offline amplifierguru
Account Disabled
Hi lineup,
Sorry, I find Leach's explanation, or excuse, for his simple cascode rather baseless.
2 BJT current sources using low noise small signal BJTs are not noisy. Zeners are.
My SKA and 300W both use 2BJT CCS's because of the superior PSRR afforded by them. Any they have NO turn on/off thump.
More of a throwaway explanation that doesn't survive scrutiny.
I tried both alternatives on my 300W amplifier (always keeping an open mind) and the sim PSRR result is here -
http://www.diyaudio.com/forums/showt...678#post790678
He has included an RC filter in the early stage supply lines to improve things.
Greg
Old 16th December 2005, 01:45 AM   #6
lineup's Avatar
Yes, amplifierguru
this is what I have learned, too.
I am always surprised to see zeners in audio amplifiers.
I have seen Nelson Pass using zeners in some earlier amps.
Do not know if he still.
I would never consider put zener diodes into where noise should be avoided.
Old 16th December 2005, 07:46 AM   #7
Account Disabled
Hi Lineup,
My experience has been that simple resistive bias with bypass capacitors gives the best audition results, THD and noise (all)compared to zeners for cascode bias.
I used this on the Magnet 300F which was rebadged and won TAS Golden Ear.
greg
Old 16th December 2005, 11:22 AM   #8
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Reliability is a second grudge for me.
Already have 6 Leach amplifier boards layed out for the Zeners, but thinking of replacing those by a string of LEDs.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 16th December 2005, 01:21 PM   #9
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Default Re: about ccs of Leach Amp
imho it is more of convience than anything, imagine stringing what? 20 led's in series to get 40 volts! so a zener in this case is more practical.
where a transitor is used with a current source or sink, an led is more practical imho.
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 16th December 2005, 01:39 PM   #10
BobEllis is offline BobEllis  United States
BobEllis's Avatar
Earlier versions did not have the zeners. IIRC, they were added at Ver 4.4 along with some other value tweaks along the way to the current version. The amp will run fine without them, and seems to fit Guru's preference for resistive biasing of cascodes.
If you eliminate the zeners R13/14 change, since they no longer have to pass the zener current. From the Leach page I saved a while ago: R13 = R14 = (V - 38.2)/5.42, where V is the power supply voltage.
Sorry Jacco, this gives you another option to try
about ccs of Leach AmpHide this!Advertise here!
My Leach Amp Clone (LEACH 150) panson_hk Solid State 32 22nd May 2014 12:25 PM
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 03:15 PM
anyone have leach PCB? ilyash Group Buys 2 7th September 2007 11:36 AM
Leach Superamp vs Leach 4.5 Samuel Jayaraj Solid State 4 26th October 2002 10:20 AM
Leach amp vs super Leach amp supernet Solid State 0 21st February 2002 11:16 PM
Copyright ©1999-2017 diyAudio
