Old 13th December 2005, 05:02 AM   #1
Account Disabled
Default Extender PCB's
During the course of panellising my amplifier board artwork for production, I am often left with narrow slivers of waste space, I pay for. So I devised these long narrow extender boards for mounting 2 sets of 3 IRFP MOSFETS or anything in the same package. The drains and sources are paralleled to suit matched devices and they are all through hole plated and solder masked both sides. They have the correct 5.5mm pin spacing.
To neaten up your project - or add HD output stage.
They're free to anyone interested (MOSFETs not included) - max 4!
See Pic -
Greg
Old 13th December 2005, 05:47 AM   #2
Account Disabled
Here's the artwork for a better idea -
Old 13th December 2005, 06:09 AM   #3
You don't use gate stopper, Greg ? Where is gate's inlet ? Blocking capacity at drains ?
Old 13th December 2005, 06:21 AM   #4
Account Disabled
Hi Pavel,
The gates are not connected to anything but there is a thin track to solder 1/2W resistors from the pad to common track. There just wasn't any room to provide for the AXIAL0.4 R's.. It's just to tidy up extensions of power stages. 3 pair.
Another thread a while back we discussed boosting the SKA for low Z loads with a conventional SF output stage by replacing the output fuses with 100R and driving 3 pair MOSFETS. It was about this time when I did the PCB but have never taken it further.
Greg
Old 13th December 2005, 06:36 AM   #5
Are you using output fuses ? They have relative high resistance ( nonlinear )... Why not fuses at drain ?
Old 13th December 2005, 06:53 AM   #6
Account Disabled
Yes Pavel,
i use +ve and -ve fuses from drains to output node, as it's common source. Thats why I can replace them with 100R resistor and drive a row of EF's with it - and they'd still be in the NFB loop. I haven't tried this yet and I thinkl the gain with 100R load or more instead of 8R might be a challenge.
Greg
Old 13th December 2005, 07:02 AM   #7
CS configuration ? Have you good protected gates against overvoltage ? When one blow, feedback " pull " there full value of driving voltage...
Old 14th December 2005, 02:20 AM   #8
Account Disabled
Hi Pavel,
Don't you worry about my CS output, both are proteced with 5V6 zeners on the gates and 10mA max current gate drive.
No takers for the extender boards?
Greg
New Bass Extender amplifierguru Solid State 31 8th October 2008 07:43 PM
USB cable extender or amplifier jacquesl Digital Source 6 6th December 2006 05:53 PM
USB active extender Risto80 Digital Source 0 30th October 2005 02:48 PM
shaft extender JAZZ2250 Parts 4 7th July 2003 04:01 PM
Page generated in 0.10063 seconds (70.28% PHP - 29.72% MySQL) with 11 queries
