Old 12th December 2005, 06:15 PM   #1
jackinnj's Avatar
Default 1nV unity gain stable opamp from ADI
in the inbox from Analog Devices, a new unity gain stable, nanovolt noise, voltage feedback opamp from ADI
http://www.analog.com/UploadedFiles/...DA4899_1_0.pdf
Old 13th December 2005, 12:16 AM   #2
Banned
Nice, but low PSU voltage...
The same with the OPA847, and not unity gain stable, but 0.85nV/Hz input voltage noise.
http://focus.ti.com/docs/prod/folders/print/opa847.html
Old 13th December 2005, 05:15 PM   #3
jcx is offline jcx  United States
1/f corner? - many new op amps are really bad >1 KHz, even 10 KHz
Old 13th December 2005, 05:33 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
... and this will result in noise levels like...? This is nothing to worry about. Noise is important above 1 kHz or so.
/Per-Anders (my first name) or P-A as my friends call me
Old 13th December 2005, 05:34 PM   #5
nuvistor's Avatar
en and in 1/f about 1kHz, see datasheet fig 13 and 16 on page 8. 10nv/rthz en at 10Hz, not bad but AD797 is about 5X better here.
Old 13th December 2005, 05:41 PM   #6
5pA/srtHz at 1KHz
Old 13th December 2005, 05:42 PM   #7
openloop is relative low (80dB) but flat all the way up to 20KHz ..
Old 13th December 2005, 06:06 PM   #8
jackinnj's Avatar
LF noise (from milliHz to a few tens of Hz) is very important for industrial T&M applications.
BOSOZ unity gain stable AudioAngel Pass Labs 1 21st August 2008 09:20 PM
Opamp question regarding unity gain markiemrboo Chip Amps 12 15th February 2007 03:40 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
NI unity gain opamp equivalent but with discretes needed jondoe Solid State 5 10th December 2004 06:45 PM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
Page generated in 0.08903 seconds (78.01% PHP - 21.99% MySQL) with 10 queries
