Marantz PM66 KI tweeks
Old 14th June 2013, 05:30 PM   #501
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz PM66 KI tweeks
I didn't double them up personally.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 18th September 2013, 11:07 PM   #502
davidwood15 is offline davidwood15
Hello again,
I finally got my old amp up and running again and it's been treating me well for the last couple of months, but I just moved house recently and it's begun to play up again!
Basically, if i turn the amp above a certain volume, the speaker protection relay clicks into action and cuts all the sound, then will come back on within a couple of seconds. It sometimes clicks on and off repeatedly, but turning down the volume generally helps.
From looking around online, most people seem to be pointing towards something as simple as needing to clean the relay connections, but I was just wondering if anyone has had this issue before and if they managed to fix it with ease.
Thanks,
David
Old 19th September 2013, 04:43 AM   #503
sextaafondo is offline sextaafondo  Argentina
Have you checked out for DC voltage at the amplifier output related to volume pot position? May be the speaker protection circuit is triggering for a reason.
In that case you'll have to trace the dc component origin being amplified.
As a side note, the relay coil is operated by the protection circuit, which is independent of the relay contacts condition.
Pablo
Old 12th December 2013, 09:04 AM   #504
curiosogti is offline curiosogti  Spain
curiosogti's Avatar
Hello
New Kid in Town
this is my working progress
Old 16th December 2013, 08:02 AM   #505
curiosogti's Avatar
Some ideas:
My other amp can donate the big capacitors so I can end with 12000x4
Is better for the bass ?
with the second transformer it doesn´t matter ??
Is this too much cap??
The s4vb20 bridge can supply 2.6 amp continuos without heatshink and 4 amp if I put one heatskink ( peak surge forward current, non-repetitive 1 cycle = 80amp)
Well I have got a metal big 35 amp bridge. I can put it near the two Transformer, in the chasis. I can put the two new capacitor (12000+12000) near the bridge, and left the original caps near the transistor...
what do you think ?
worth it ??
PD: sorry for my english
Old 23rd January 2014, 06:28 AM   #506
Ben Hanke's Avatar
Hi curiosogti,
Your English is fine. Brent had 22,000uF Silmics in his amp, so doubling the caps should be OK.
Nice job with your placement of the second transformer. It looks good.
Ben
Old 25th January 2014, 04:26 PM   #507
ginetto61 is offline ginetto61  Italy
To answer the question about capacitance ... from the beginning of the 3D
Originally Posted by Fidelity Audio View Post
I have done quite a few mods to this amp now so I thought I should post a pic.
The most noticable mod is the rather small res caps. lol
The bass is very good from these caps and no loss of treble etc.
Maybe this is too much. But 2 nice 47000 uF ...
gino
Old 23rd September 2014, 10:35 PM   #508
Ben Hanke's Avatar
Hi folks, has anyone thought about doing anything to improve the input selection switch?
I noticed the other day that I can hear cross-talk between inputs if I switch to phono while I have a CD playing. I was wondering if a relay-based input selector might be a better solution? I'm thinking I could keep the current switch connected so the dial still works, but repurpose it so that instead of switching an audio signal, it diverts power to the appropriate input relay.
Any thoughts?
Ben
Old 21st February 2016, 03:31 PM   #509
Bevan Court is offline Bevan Court
Hi Ben
I'm not sure if you still have your kisig, if so, I have a question, what voltage do you have? I brought mine with me from the UK and I've never found a good transformer.
I've also got one channel out that I need to change, which km only going to try and fix if I can find a reasonable solution for the transformer.
Bevan
Old 13th October 2016, 07:50 AM   #510
Ben Hanke's Avatar
Hi Bevan, sorry for the delay in replying; I've been on a break from modding. Yes, I still have my KI. I have the 240v running on a 3kw step-up transformer from Amazon (model PowerBright VC-3000W)
Marantz PM66 KI tweeksHide this!Advertise here!
Marantz PM66 se problems, information wanted alan_w Solid State 19 5th October 2015 12:36 PM
Quad II Mods/Tweeks slurb.net Tubes / Valves 62 16th June 2012 12:32 AM
wanted marantz pm66 amp paul.42 Swap Meet 0 6th April 2009 08:09 PM
Tweeks on tubes - bring out the demagnetiserss ashok Tubes / Valves 36 3rd August 2004 05:34 PM
expert tweeks for PA? Pbassred Multi-Way 4 7th December 2003 08:57 PM
