Marantz PM66 KI tweeks
Old 14th June 2013, 05:56 PM   #491
Mooly's Avatar
Originally Posted by col996s View Post
Hi. I am hoping to do the Bridge rectifier mod. I have some MBR20200CT diodes but I noticed on the data sheet it looks like there are two diodes in one package.
Do you just use one in each package?
Does anyone have information on how to do this please?
You would have to show what you are trying to do because these are indeed a dual diode device with common cathodes
To make a bridge using just these would need three such pakages for minimum parts count and four to do it properly.
Old 14th June 2013, 06:03 PM   #492
col996s is offline col996s  United Kingdom
Thanks. I've got four so I think I'll use all 4 and just use a single diode in each packet.
I'm trying to replace the bridge rectifier with shotkey diodes. I thought this was a worthwhile mod?
Old 14th June 2013, 06:08 PM   #493
Mooly's Avatar
Well I would probably parallel the two diodes in each package and gain the benefit of higher overall current handling and surge capability. The volt drop at high currents would be marginally lower too.
Old 14th June 2013, 06:10 PM   #494
Ok thanks. I want zero risk of damaging the amp so if this is ok i will.
Old 14th June 2013, 06:12 PM   #495
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz PM66 KI tweeks
That's what I did, and I was very happy with the result. I didn't expect it to make much of an audible difference, but it did.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 14th June 2013, 06:14 PM   #496
Thanks. Did you parallel them up?
Old 14th June 2013, 06:15 PM   #497
Mooly's Avatar
No such thing as zero risk, but, if those diodes are OK spec wise for what you want and you wire them correctly then it will work.
Old 14th June 2013, 06:17 PM   #498
Thanks. I meant doubling them up.
Old 14th June 2013, 06:19 PM   #499
Mooly's Avatar
Doubling them up can only improve the reliability.
Just get them fitted
Old 14th June 2013, 06:25 PM   #500
Yes sir!
Marantz PM66 KI tweeksHide this!Advertise here!
Marantz PM66 se problems, information wanted alan_w Solid State 19 5th October 2015 01:36 PM
Quad II Mods/Tweeks slurb.net Tubes / Valves 62 16th June 2012 01:32 AM
wanted marantz pm66 amp paul.42 Swap Meet 0 6th April 2009 09:09 PM
Tweeks on tubes - bring out the demagnetiserss ashok Tubes / Valves 36 3rd August 2004 06:34 PM
expert tweeks for PA? Pbassred Multi-Way 4 7th December 2003 09:57 PM
