Marantz PM66 KI tweeks - Page 48 - diyAudio
Old 21st December 2012, 07:55 PM   #471
Send a message via Yahoo to conker99
Default r802
hi.im a total newbie, could somebody please post me the spec of the r802 resistor . im getting confused with watts ohms voltage etc!!!!! or mail me a direct link where to buy one ??? thanks. conker99@yahoo.co.uk
Old 22nd December 2012, 08:30 AM   #472
Hi and welcome to the forum.
There is something of a problem with finding a schematic on the web for this amplifier to be able to help. You have the part in front you and resistors have colour bands, which are a code for the resistance value and tolerance or some have it written in shorthand form like 120R or 1k2 which means 120 ohms and 1,200 ohms respectively, for example.
Assuming it is the value you want to know and not some exotic part brand you a5re trying to source, you could tell us what you read and send us a small, clear pic, attached to your post.
Ian
Old 22nd December 2012, 03:04 PM   #473
Default r802
hi ian. thanks for your welcome and reply. i have taken a pic of the resistor,it is the left hand resistor of the couple in the middle. i think the bands are gold , black , purple , yellow . if you could cofirm its properties for me i would be very grateful. thanks.
Old 22nd December 2012, 03:10 PM   #474
Mooly's Avatar
47 ohm. Looks like 1watt metal oxide, which is specified for "safety". In the event of a fault it shouldn't smoke too much... which scares the punters
(It doesn't look burnt or discoloured to me)
Old 22nd December 2012, 03:21 PM   #475
thanks mooly.i agree it looks ok !! looking on here many seem to have the same problem as me ( lights come on,no output to right hand channel ) and replacing r 802 seems to be the place to start.
Old 22nd December 2012, 06:58 PM   #476
Mooly's Avatar
Have you measured this resistor on a meter.
(I've not followed this thread and I'm not familiar with the amp but post #15 mentions R801 and 803 as being 47 ohm resistors that may be a stock fault.)
Old 23rd December 2012, 10:39 PM   #477
Default r802
hi mooly.thanks again for your interest,i have a mate who is going to meter test and do the soldering if needed next friday,im just trying to get the bits i may need before hand, resistors are cheap so if its not that thats the problem its no loss financially,i jsu cant get my amp up and running quick enough !!!! i will look at r801 and r 803 also. thanks for your help.steve
Old 24th December 2012, 10:04 AM   #478
AmpPM57 is offline AmpPM57  United Kingdom
Can these tweaks be adopted for the pm-57?
Old 30th December 2012, 09:43 PM   #479
hi all
brilliant thread will be starting mods soon
has anybody replaced/upgraded the AN7062P input chip - different chip or possibly discrete solid state stage on seperate board or even valve stage !! you lot have replaced everything else just about - haha
trouble is now i really need a second ki tx
james
Old 14th January 2013, 11:40 PM   #480
Originally Posted by davidwood15 View Post
Hi Guys, posted in another thread a while back but had no luck!
I had the problem of the power LED coming on and no clunk, so I opened up my amp, replaced both the 47R that are known to go and also a 1.2k that looked very charred.
Now my amp turns on, does the "clunk" but still refuses to have any output.
Does anyone have the slightest idea what may be causing this? This is my first ever project and it's stumped me!
Just giving this a bump in case anyone is able to help. I'm still completely stumped.
Marantz PM66 se problems, information wanted alan_w Solid State 19 5th October 2015 12:36 PM
Quad II Mods/Tweeks slurb.net Tubes / Valves 62 16th June 2012 12:32 AM
wanted marantz pm66 amp paul.42 Swap Meet 0 6th April 2009 08:09 PM
Tweeks on tubes - bring out the demagnetiserss ashok Tubes / Valves 36 3rd August 2004 05:34 PM
expert tweeks for PA? Pbassred Multi-Way 4 7th December 2003 08:57 PM
Copyright 1999-2017 diyAudio
