Old 31st October 2009, 03:22 PM   #281
canetoad's Avatar
If you're going to replace a lot of the components wouldn't it be cheaper to buy an SE and replace the tx with a toroidal version? I'm trying to source a KI and they are a bit thin on the ground. SEs are a lot cheaper too.
Bernie.
Old 1st November 2009, 11:43 AM   #282
nuryev is offline nuryev  Australia
Default PM66KI mods
Amplifier channel successfully rebuilt, and sounding great - thanks to some of the great people on this site who contributed provided information, sources for components and patience.
Thanks diyAudio -you guys are a great bunch
NYV
Old 27th February 2010, 05:48 PM   #283
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
@Brent:
I converted the phono inputs in my PM66KI to another set of line-level ones (I don't have a turntable). Problem is, because the phono setting on the source selector switch was never used, the contacts on the attached PCB switch are dirty. When I use this position I have to twiddle the knob a bit to get the left channel to come in.
So, can I:
a) get a direct replacement for this switch (i.e., is it a standard alps part or something)? I didn't pay much attention to it when I had the amp apart.
b) can it be opened and cleaned?
c) is there something I can squirt into it that will do the job without endangering the other contacts?
Cheers!
Old 3rd March 2010, 07:36 AM   #284
Fidelity Audio's Avatar
Hi Glenn
The top clips off the switch, usually switch cleaner and lots of sliding of the switch will sort it out.
While it is in bits you may as well bypass the source direct etc (or have you already done that?)
I had to remove the phono pcb in mine due to the larger heatsinks LOL
Brent
Old 3rd March 2010, 09:36 AM   #285
Glenn2's Avatar
Thanks for that Brent!
I'll have a go on a wet Sunday soon (probably won't have to wait long...)
Cheers.
Old 26th October 2010, 03:50 PM   #286
It's that time and a sad time. I'm selling the uber 66KI
It's been my rear channel amp for the last 6 month and to be honest it's a waste there. Not sure how much I want for it but i'm open to sensible offers. It would also have to be local pick up as the two transformers are layed down rather than bolted down.
Brent
Old 28th October 2010, 04:39 PM   #287
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
Sad news indeed, Brent. I've been following this thread for about 4 years now, and was recently inspired to gradually start following your mods list. I got the Black Gate cap swaps done so far, and I expect I'll probably continue, although the transformer is hard to get without breaking an amp and those Silmics of yours seem pretty unique (you recently recommended Mundorf to me as alternatives). I hope it goes to a good home and you decide to keep the pics and docs up on your site.
Old 18th November 2010, 06:02 AM   #288
triocat is offline triocat  England
Hi Bwent
newbie here, read the posting again and again, bought what was a faulty KI66 to find tit sounds great, got it off ebay and watch yours go too, indeed sad, but not for the buyer.
So many questions, TX, cap values, heatsinks from, what first, what next, when, eh?
so will you be running a day course ' getting to know my KI' with tea and biscuits
Super posts
Tc
Old 24th November 2010, 01:00 PM   #289
helllloooo?
Old 9th December 2010, 10:53 AM   #290
hi kinda new here, been following the 66Ki tweeks and all and thought i would keep a brief here on my upgrades to the 66KI, of course following closely to Rowemeister who has been great help so far.
Bought a 66KI from ebay - said not working but was working fine when i fiddled with the speaker outputs. the sound is good with a good balance of bass and treble with clarity.
so the amp will be used for a full system - CD17, tuner, vinyl and a CC45 multiCD.
so the very first thing i did was look inside, quite sparsh for a large box.
Then without any cost i removed the wire from the RCA board (PV01)to the board with the record and direct control (PS01), I then wired from the Master volume to the RCA board with the 4 core cable that was from the MV to the PS01, using R,Rgnd, L Lgnd, this is simple to do. By missing out the PS01 board the sound has a cleaner route and does sound better, clarity improved. This cable will be changed for better cable here and from MV to power board, using 20AWG jupiter solid copper.
Next smoother caps and bridge rectifier to change, i have some 63000uf/63v BHC caps coming, but i am working out how to install the new diodes, inductors and bleeder resistor within the current board.
Happy soldering.
Tc
Marantz PM66 se problems, information wanted alan_w Solid State 8 6th August 2012 05:13 PM
Quad II Mods/Tweeks slurb.net Tubes / Valves 62 16th June 2012 12:32 AM
wanted marantz pm66 amp paul.42 Swap Meet 0 6th April 2009 08:09 PM
Tweeks on tubes - bring out the demagnetiserss ashok Tubes / Valves 36 3rd August 2004 05:34 PM
expert tweeks for PA? Pbassred Multi-Way 4 7th December 2003 08:57 PM
Copyright ©1999-2013 diyAudio
