Marantz PM66 KI tweeks
Old 5th July 2007, 11:19 AM   #111
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Also can you post a pic of the TX used in the 6010 KI
cheers
Brent
Old 5th July 2007, 11:22 AM   #112
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
No - I've got a 66KI!
Old 5th July 2007, 11:30 AM   #113
LOL - thats Thomo with the 6010
Brent
Old 5th July 2007, 11:44 AM   #114
Glenn2's Avatar
Yeah he supplied me with the service manual I think.
I wonder, as 22uF is a more sensible value, it may have been designed with this, but as Marantz put those 220uF Silmics everywhere they probably switched it to 220uF for convenience.
Old 5th July 2007, 01:07 PM   #115
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
TX pic coming up.....
I think it's same spec as pm66ki, but it's copper shielded.
Lee.
Old 5th July 2007, 01:26 PM   #116
Thomo's Avatar
pic 1
2nd pic
Old 5th July 2007, 01:35 PM   #117
Yes it looks identical apart from the copper.
It does give me an idea though lol
cheers
Brent
Old 6th July 2007, 03:04 PM   #118
I have bolted my heatsinks together and will leave over the weekend as the compound keeps spunking out. I will then torque up the bolts again and clean up ready for fitment.
They will also add extra mass to the cd player lifting the heatsink weight from 360g to 1.82Kg. Amp should be approx 13Kg
Brent
Old 9th July 2007, 04:01 PM   #119
All fitted now. I have not had time to post pics and will do that tomorrow.
I did however weigh it.... 12.62Kgs
Also I am running the idle @ 150mA and all is cool. Before 100mA got too hot.
Brent
Old 9th July 2007, 09:55 PM   #120
jimh0612 is offline jimh0612  United Kingdom
Default Input caps
Originally posted by rowemeister
Its actually 220uF on the 66 too. Lots of errors on the sch, but when you look at the parts list its right. They corrected them mistakes on the 6010 sch.
I swapped mine for the BG AC 50V 10uF. I picked 10uF as the output caps in the cd are BG AC 6.8uF.
Brent
Hi Brent
Which are the input caps on this amp?
I've done most of the mods on your list from a while back when you posted the pics of your bazookas, but the BG AC 50 isn't listed.
I'd also like to do the Schottky bridge mod but not sure how to do it. I've found schematics on how to put a bridge together from schottkys but to be honest it was a bit over my head.
I'd really appreciate any tips.
Ps any further with the 3020SE in your dining room - you seem to have been busy recently.
PPS EXCELLENT new heatsinks they're even bigger than the Kenny now!!
Jim
Marantz PM66 KI tweeksHide this!Advertise here!
Marantz PM66 se problems, information wanted alan_w Solid State 19 5th October 2015 01:36 PM
Quad II Mods/Tweeks slurb.net Tubes / Valves 62 16th June 2012 01:32 AM
wanted marantz pm66 amp paul.42 Swap Meet 0 6th April 2009 09:09 PM
Tweeks on tubes - bring out the demagnetiserss ashok Tubes / Valves 36 3rd August 2004 06:34 PM
expert tweeks for PA? Pbassred Multi-Way 4 7th December 2003 09:57 PM
