Old 29th June 2007, 03:02 PM   #101
Fidelity Audio's Avatar
It is true simon they are silmics but I suppose BG on em may be worth a try
Brent
Old 29th June 2007, 03:30 PM   #102
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
A little off topic I know but....
I have just been given a Phase Linear PL700 to repair by my mate. This is rated at ~750 watt per channel into 4 ohm.
I reckon that would drive your speakers Brent!
Lee.
Old 29th June 2007, 04:33 PM   #103
LOL Do you reckon
Brent
Old 5th July 2007, 09:08 AM   #104
I received my heatsink components late yesterday. I have mounted the main part into my test amp and have rested the veins up against it.
So this should give some idea of the final look.
Brent
Old 5th July 2007, 09:12 AM   #105
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Lookin' good mate, I'm sure you did rest your blue veins up against it
Old 5th July 2007, 09:46 AM   #106
Fins then
Brent
Old 5th July 2007, 10:08 AM   #107
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Morning Brent,
I was looking at the schematics of the 66 and the 6010 which are practically identical.
The 6010 lists the input cap as 220uF but the 66 as 22uF.
Looking at the impedances involved 220uF look awfully large.
What is used? If it IS 220uF why do you think it's so big?
Even 22uF is a bit on the big side. My old Rotel had 1uF film.
Confused... unless I looked at the wrong part.
Old 5th July 2007, 10:13 AM   #108
Its actually 220uF on the 66 too. Lots of errors on the sch, but when you look at the parts list its right. They corrected them mistakes on the 6010 sch.
I swapped mine for the BG AC 50V 10uF. I picked 10uF as the output caps in the cd are BG AC 6.8uF.
Brent
Old 5th July 2007, 10:16 AM   #109
Glenn2's Avatar
Ah... the reason I was asking is I have some BG N 10uF/50V lying around (new and unused) and thought they would be good here.
Old 5th July 2007, 10:18 AM   #110
Pop em in and test. Should be ok.
Give it a few hours to settle
Brent
Marantz PM66 se problems, information wanted alan_w Solid State 8 6th August 2012 05:13 PM
Quad II Mods/Tweeks slurb.net Tubes / Valves 62 16th June 2012 12:32 AM
wanted marantz pm66 amp paul.42 Swap Meet 0 6th April 2009 08:09 PM
Tweeks on tubes - bring out the demagnetiserss ashok Tubes / Valves 36 3rd August 2004 05:34 PM
expert tweeks for PA? Pbassred Multi-Way 4 7th December 2003 08:57 PM
Copyright ©1999-2013 diyAudio
