diyAudio Moderator Emeritus
Having DIY audio as a hobby is like looking for trouble
A very good thread (but unfortunately short) is here : Open loop gain (High or low) ? From my experiments, I found something that makes me wrote this thread. I think I heard (not measure) that compensation caps are ruining the sound (while they are needed for stability). These caps are small pF caps in 3 places : Miller dominant cap (B-C cap in VAS), feedback cap (the one which is // with FB resistor), and feedforward cap (from VAS to inverting input). While searching for the "optimum" values (that is needed for stability) that also have the best sounding one, I "feel" that the best value for those 3 caps are 0 pF (or don't use them), in the sound quality point of view. Here in DIYaudio, many experienced designers uses criterion like Bode plot while designing an audio power amp. This enables us to design an amp that have a certain value of OL/CL/FB gain. The best ratio of these 3 that gives best sonics can be found by listening to an experiment prototype. If I'm not mistaken, AKSA and JCarr have wrote somewhere that there is a "best" OL/CL/FBgain ratio that gives the best sonics. The Motorola application note of 100/200W audio power amp also gives indication of how much feedback they consider is the best. If I continue to insist of not using those 3 pF caps, the result will be something like LC's End Millenium or Nelson Pass' various cct's. (Interesting that NP has changed from complex cct's to very simple ones, from high gain bipolars to low gain mosfets, but why?) Recently, Amplifierguru also share that he tries to advoid the use of dominant cap by tailoring the RE in the differential pair until it stabilize. Is it wise to insist not to use those 3 pF caps in designing an amp (that means the OL and FB factor will be low, lots of local feedback/REdegeneration, distortion will be quite high as the result)? Or I have to search for a certain value of OL/CL/FBgain balance that gives the best sonics, and still use those 3 pF caps? What is the sonics (audible) difference between a design that uses lots of OLgain (and then kills them with lots of feedback) and a design that is simple, low OL gain? Is the picking of those 2 related to the power rating of the amp (10W or 500W)? |
#2 |
Janneman, what do you think?
#3 |
the Miller compensation cap around the VAS is specifically referred to by JLH as ruining the sound quality of an amplifier. Many other commentators allude to the same problem. The global feedback caps do have an influence and that has given rise to the omission of the GFB, both resistive as well as capacitive, in some designs. I have never yet seen critisism of the cap returning to the inverting input on sound quality grounds. I have seen a few references to this form of stabilisation being more difficult to achieve. Given the multiple stability components used in amps of this type then I am inclined to agree. But never having designed this style I do not know how easy or difficult that might be. Very low global feedback does exagerate the ratio of low harmonics to higher harmonics and some commentators have referred to this as having a poor sound and it certainly produces an amplifier that measures badly. So it seems you have choices;- 1. no global FB, 2. very low GFB, 3. low GFB and 4. high GFB. Most go for 1 or 3 Who is going to teach us how to produce and use Bode and/or Nyquist plots?
regards Andrew T. |
#4 | |
Hi, AndrewT,
The feedforward cap (VAS to inverting input) do not change much the highs BUT it really makes the music quite not enjoyable. (I compare it in the same cct using it or not using it, A-B switch). Something like phase modulation or IM, I don't know. I think this is more destructive than Miller cap or //feedback R cap to the sonics. I didn't wrote this in the first post, because many commercial/successfull amps are using this cap. This feedforward cap usually not big in value (20pF max), and have very good properties in solving oscilation problems. If others uses it, could it be not that destructive? If someone didn't use A-B switch comparison, maybe he wouldn't know what this little pF do to the sonics. Usually when someone have overcome the oscilation problem, he is glad enough to forget to wanting to know what this pF cap does to the sonics. But since I'm not focusing on stability issue now (more to sound quality issues), I would like to know whether others have noticed this? |
#5 |
Cdom must have good linearity vs. applied voltage (especially in high power amps as the "see" the almost the whole of the output voltage swing).
I have made amps with cheap ceramic high voltage caps as Cdom, only to find that the result was poor sounding. I now use silver mica caps in this position as they are very linear and much more stable at different voltages and temperatures. Bottom line is that this cap must be of good quality and may in fact be the limiting sound quality factor in a given design (IMO). \Jens |
#6 |
Actually most high feedback amplifiers have high feedback (>50dB) for low frequencies, where it is not so much needed both from engineering and psychoacoustic point of view.
There is no reason why one would need THD+IM<0.001% at 1kHz whereas at 20kHz it is >0.5%. All you need is to have ~30-35dB of feedback factor flat across audio range, better to have -3dB point above audio. That's my view, to compare dr. Leach suggests to have up to 25dB of feedback with dominant pole above 30kHz. |
#7 | |
Sounds great !Mike |
#8 |
A bit hard with dominat pole compensation...
#9 |
You must not forget that, because of parasitic capacitors inside and outside the devices, there is always some Miller compensation.
I have built many Linsley Hood amps with feedforward comp which, I think, needs a lo-pass filter ahead of the amp. My JLH amps were more sensitive to others to radio breakthroughs. Douglas Self has clearly explained why a large open loop bandwidth cannot be obtained without being detrimental to the open loop gain at low frequencies. My current idea, not entirely established, is that the open loop phase should be less than 90° in the capacitive region of a loudspeaker where current/voltage phase can reach 45°. For most speakers, this would advocate for a 2 kHz open loop bandwidth. Despite the huge amount of subjective comments, no correlation exists between them and good design rules. The first of these is that one must not tolerate any trace of unstability. The most sure way to achieve this is to use a Miller compensation, whatever said elsewhere. ~~~~~~~ Forr §§§ |
#10 |
Is it right that a design with lots of OLgain (and then kills them with lots of feedback) sounds more detailed, like in finger moving on guitar string sound? Is this the goal of such a design?
| hi-loop gain amp | mfc | Solid State | 49 | 10th January 2009 07:10 AM |
| Gain Blockwith Variable Loop Gain | Bonsai | Solid State | 17 | 11th July 2008 03:40 PM |
| open loop gain,how many is enough? | Leolabs | Solid State | 28 | 17th May 2006 10:00 PM |
| Gain loop formula | fscarpa58 | Everything Else | 2 | 16th January 2004 12:19 PM |
| Open loop gain (High or low) ? | JensRasmussen | Solid State | 19 | 16th September 2002 10:26 PM |
| Page generated in 0.13940 seconds (82.59% PHP - 17.41% MySQL) with 11 queries |
