Old 10th December 2005, 02:21 AM   #1
bordins is offline bordins  Thailand
Default High voltage isolation from set-top-box ?
New digital cable TV offers 24-hr music channels to subscribers. I upgraded the old analog system to this new service. I have a problem connecting audio-out from my set-top-box to my stereo. High voltage leaks into the RCA cables, certainly into my preamp.
Is there any concern about such leak ? I'm afraid my preamp will burn. Is there a way to isolate high voltage ?
Thanks.
Old 10th December 2005, 10:53 AM   #2
djk is online now djk
djk's Avatar
http://www.edcorusa.com/sound/matchers/s2s10k_10k.htm
Old 10th December 2005, 02:57 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi bordins,
That's a common problem over here too. See if the cable company can supply a 1:1 Balun to break the cable ground connection. I normally install this as the first connection from the street. That way you won't get a sneak path back through something else. You may need on to the TV if it's generating noise on the ground.
-Chris
Old 11th December 2005, 08:00 AM   #4
Thanks djk and anatech.
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
Voltage in and out of an isolation transformer? riotubes Parts 3 30th November 2008 11:24 AM
isolation transformer - high voltage. atmars Tubes / Valves 7 16th July 2008 04:34 AM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
Page generated in 0.08190 seconds (73.78% PHP - 26.22% MySQL) with 10 queries
