Old 9th December 2005, 03:43 AM   #1
bob_v5 is offline bob_v5  England
Default irf 740 replacement
Hi, ive blown up the amp i was making. it was good for about 150 watts in 4ohm but then burnt out. i had 2 irf740s on each side. (push pull config)Do you think i should rebuild it with 4 on each side or go for bigger mosfets? if so any recomendations?
Old 9th December 2005, 04:24 AM   #2
CBS240 is offline CBS240  United States
CBS240's Avatar
Are you sure it was SOA that caused failure? It is possible that some other circuit condition caused the smoke. A basic schematic topology illustration would be helpful for people here to make better suggestions.
All the trouble I've ever been in started out as fun......
Old 9th December 2005, 05:42 PM   #3
hmmm, well it was working fine at lower power. Into 8 ohms it was fine. what is SOA? The circuit is a quasi complimentary mosfet design. It is based on a circuit in a magasine, but i doubled the voltage and uprated all the components. +- 75v, total 150v swing. My friend whos being building amps before i was born helped me design it so im sure hes right when he says i need bigger output devices. Always welcome to a second opinion tho. I'l c if i can post the circuit, but will just be a photo of the diagam so i dunno if it will be readable.
Old 9th December 2005, 05:42 PM   #4
here it is, cant really see very gud tho
Old 9th December 2005, 07:47 PM   #5
CBS240's Avatar
Looks readable to me... You did change the top MPSA56 as Vce max is only 80V? This is current source for VAS(which 2N5551 should be fine) The current source will be exposed to rail to rail volts as well, Vce 150V, maybe use 2N5401? Also you may consider a 1K resistor in series with the base of the current source for the differential. If the current source for VAS saturates, it could affect differential bias.
SOA is Safe Operating Area. When you look at a transistor datasheet, it will have a SOA graph that plots Vce vs Ic and shows maximum instantaneous power dissipation allowed before failure. (go by the DC curve) Driving devices hard with lots of voltage on them will cause them to melt. Your friend is probably correct that you need more transistors. Of course more transistors will require more drive, so a driver stage may be necessary. Your almost in the realm of redesign here.
Old 9th December 2005, 09:58 PM   #6
yea i changed all of them to either 2n5401 or 2n5551.
Old 10th December 2005, 03:16 PM   #7
what about using bigger mosfets then? I dont really want to redesign it.
Replacement LED DreadPirate Parts 11 14th November 2009 05:45 PM
Replacement amp for A-Bus? Greg911 Class D 0 16th November 2008 03:33 PM
MTX 5 ch pot replacement pk386 Parts 2 1st October 2006 05:32 AM
replacement cap for T-amp: How big? MEXXX Class D 5 10th December 2004 01:30 PM
Replacement for 5R4 Ralph Tubes / Valves 8 16th December 2003 11:02 AM
Page generated in 0.10555 seconds (69.42% PHP - 30.58% MySQL) with 11 queries
