Variable phase subwoofer
Old 20th October 2002, 01:38 PM   #1
palesha is offline palesha  India
Default Variable phase subwoofer
I have seen new subwoofers with variable phase. Anybody have designed or used this type of circuit? I will like to know more about the circuit so that i can add the same to my subwoofer.
Mahendra Palesha
Old 21st October 2002, 11:09 AM   #2
f4ier is offline f4ier  Australia
f4ier's Avatar
The circuit is called an All-Pass Filter; linkwitzlab.com has a bit of information on a first order APN -- http://www.linkwitzlab.com/filters.htm
hth
Isaac
Crossover/Subwoofer Simulator
Old 22nd October 2002, 03:24 AM   #3
dhengkoel is offline dhengkoel  Indonesia
dhengkoel's Avatar
Try this link too: http://www.rane.com/library.html
Regards:
ragil.hastomo
:: The last but not least ::
Old 22nd October 2002, 05:02 AM   #4
argo is offline argo  Estonia
Both circuits (shown on Linkvitz page and Rane manuals) will work
BUT you need Exponential curve tracking potentiometer (single for 180 deg and dual ganged pot for 360 deg variations) to make these circuits usable.
Argo
Old 22nd October 2002, 04:57 PM   #5
argo,
Can u give details of the circuits u have mentioned at the two sites? More information about the Exponential curve tracking potentiometer is required.
MP
Old 23rd October 2002, 08:16 AM   #6
Originally posted by palesha
argo,
MP
Isaac has already shown a typical allpass filter - also called delay filter i.e. a filter that passes all frequencies and only delays the signal to certain degree and consequently alters the phase. The gain of the filter is 1. The value of the Rf is kept equal and unchanged while by changing the value of resistor R you can delay the signal - here is where you need potentiometer. But changing the resistor R value doesnít alter phase by linear relationship but logarithmically. For an example: turning your 10k linear potentiometer from 0 position to 50% of its turn will not change phase from 0 deg to - 90 deg as you would have wanted, 75% turn wonít change the phase to 135 deg, and so on. Thatís why you may want to use exponential (inverse logarithmic) potentiometer in order to maintain linear scale when turning your potentiometerís knob.
Now if you use one of such filter bloc, you can change the phase from 0 to - 180 deg, if you use two of those identical blocs (hence the dual pot need) in series it will be possible to change the phase of the signal from 0 to -360 deg.
Look also at http://www.linkwitzlab.com/filters.htm 4 - Delay correction
and http://www.rane.com/pdf/ac22sch.pdf find detail 2: Rane's typical delay circuit.
Argo
Variable phase subwooferHide this!Advertise here!
variable phase 0-180 deg. Marcelinho Subwoofers 3 31st December 2006 01:14 AM
Circuit for variable phase 0-180 control for active L/R xover georgehifi Solid State 4 20th September 2006 09:55 AM
Subwoofer variable phase control AudioFreak Solid State 23 18th July 2004 03:54 PM
Simple variable subwoofer Crossover.. deepanger Solid State 5 25th February 2003 01:47 AM
Variable phase circuit for sub ergo Subwoofers 1 29th August 2001 12:06 PM
