I've built several headphone chip-amps and would like to build a simple but good performing discrete power amp for my office speakers. They are inefficient but decent sounding, and would like to get at least 100W x2 into 8 ohms. I found the c200 at ampslab. Are there other simple, easy-to-build discrete DIY designs of similar (or higher) caliber that I could look at?
TIA, -Jason |
#2 |
NICE
I TRY THIS ESCHEMA |
#3 |
Account Disabled
Hi halusha,
You might like to check out the new 'Simple Killer Amp' I designed earlier this year, it's available as a kit (without heatsink) - http://members.dodo.com.au/~gregball/guru_004.htm and is discussed quite thoroughly in - Simple Killer Amp! This design delivers more efficiency, more performance, is 'patent pending', simple to build and, for now, low cost. You can build two simple low cost monoblocks (only needs 160VA traffo) and blow the monster amps away. Cheers, Greg |
#4 |
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum |
#5 |
Thanks for the suggestions/links!
#6 |
AKSA with out a doubt http://www.aksaonline.com/welcome.htm
#7 |
Halusha,
Delighted to discuss the issues by PM here. Cheers, Hugh |
#8 |
hugh
i wouldnt mind some pointers on PA design...i still have trouble figuring out how much current the input stage and the VAS require, say for class A??..and how do you work out the miller cap value? |
#9 |
Hi DW,
Hmmm. How do you describe all the parameters of a PP Class A SS amp in a few sentences? Tricky........ Stage current in the input diff pair need not be much more than 1mA. Anything up to 5mA is fine, with jfets needing more to extract the last bit of transconductance. Stage current in the voltage amplifier depends upon: 1. Number of output pairs, their beta, and input capacitance. 2. Bipolar or Mosfet. 3. Driver parameters. 4. Required slew rate. 5. Stage current in diff pair. 6. Rail voltage. 7. Loading of the VAS output; sometimes a resistor is used here, as in the Symasym 5 from Michael Bittner. As a general rule, for 36V rails, a 60W into 8R amp, around 7mA is sufficient with a high beta bipolar output stage. Increase this around 40% for mosfets, since they have no driver and are connected directly at the gate to the VAS output. When you look at amp design, there are a myriad of designs and operating points out there, and some are just plain wrong, yet they work OK. You have to do your testing carefully, and move the operating points up and down until you get the optimum sonics. This takes time and effort. Miller capacitance calculation is possible to calculate, but it's tricky because of parasitics in the circuit board and other spurious issues around the design. As a general rule, the best approach is empirical. Start around 100pF, and using standard values, move down to the minimum. The amp will become audibly fuzzy and distorted at too low a value, and may even blow up the speaker AND the output stage; go up 10pF from this point, and move forward in 5pF steps from this reference. The value will change with layout, component choice, etc. Of course, it goes without saying that you should use a conventional loudspeaker with commonplace impedance characteristics; you will find that the optimum miller cap for one speaker will be different for another. This is perhaps what makes it so difficult; you have to make the amp stable for all loads, yet too much Miller capacitance will destroy the sonics. Hope this at least introduces you to the complexities; it's not particularly scientific, more empirical, but there is a very good reason for this; there is no standard load, and the amp is not judged on its specs but rather on its sonics - a highly subjective, market judgement which any designer ignores at his peril. Cheers, Hugh |
#10 |
DW?..lol..im sure thats from a cartoon..ah yes..darkWing duck..hahahhhhaa..used to love that show..nice one hugh
..thank you so much for the paragraph you wrote..being as that i am inexperienced, i will go away and digest this stuff...may i ask more questions if needed?..thnak you once again i really appreciate it
| EL34 simple push pull class B : why 100W ? | bozole | Tubes / Valves | 13 | 1st July 2009 05:26 AM |
| Discrete simple headphone amp | kubeek | Headphone Systems | 15 | 7th September 2007 04:13 PM |
| Simple 110 - 240 VAC to 2 x 30 VDC 50 - 100W SMPS .... where do I start?? | Baldin | Power Supplies | 4 | 10th February 2007 12:12 PM |
| Simple(ish) discrete op-amp | Mr Evil | Solid State | 21 | 25th June 2005 09:09 PM |
| simple designs for 50-100W amplifer | TomJ | Solid State | 2 | 7th February 2003 05:17 PM |
| Page generated in 0.12249 seconds (77.38% PHP - 22.62% MySQL) with 10 queries |
