Old 6th December 2005, 01:31 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Default Another look of Lizi
Here she is,with modified input stage.Theoritically,the first stage is around 5mA and the second stage is around 10mA.Still waiting for critics and recommendations
Old 6th December 2005, 06:44 AM   #2
Account Disabled
Hi Leolabs,
Much nicer. This would benefit from chip drive - would set DC conditions.
Otherwise you should put in a FB C or offset adj. How's the THD?
Simple but weak in the PSRR and wastes supply V.
greg
Old 6th December 2005, 07:03 AM   #3
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Fully symmetrical, haven't seen much of that around here.
Why load the Vas instead of using a buffer, you don't like drivers ?
Those fancy input and output devices deserve separate rails, and saves some volts to please Mr Ball.
Why not add filtering to the lines feeding Q1 and Q2, or use CCS's ?
Kind of ironic that so few give a shot of trying a fully symmetrical design driven by an opamp, as if it were a thing of the past.
I see we had a 12 hour blackout ?
Looks like Sponge Bob has killed another thread.
Old 7th December 2005, 02:46 PM   #4
Leolabs's Avatar
Ok,added her with local filtering caps,and reduced her supply voltage to +/-24V
Try to keep her as simple as possible,so only 3 stages,and NO BUFFER for drivers,and NO OPAMP.
Old 7th December 2005, 02:49 PM   #5
Leolabs's Avatar
The second stage now operating at around 20mA.
latest version of Lizi Leolabs Solid State 95 29th June 2008 03:01 AM
Workable Lizi final Leolabs Solid State 19 15th May 2006 02:44 AM
Lizi final Leolabs Solid State 1 1st February 2006 02:39 AM
Meet Lizi,on the paper Leolabs Solid State 9 5th December 2005 01:41 AM
Page generated in 0.07610 seconds (72.73% PHP - 27.27% MySQL) with 11 queries
