Old 2nd December 2005, 02:47 PM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Default Meet Lizi,on the paper
Here she is,on the paper,any comments are welcome
Old 2nd December 2005, 03:16 PM   #2
MikeB is offline MikeB  Germany
MikeB's Avatar
Hmmm, unless you use cascoded jfets in input it is very unlikely to be functional at all ? Or am i wrong ?
Mike
Old 2nd December 2005, 08:00 PM   #3
Banned
i cant see it very well being turned vertically,very symmetrical,
did you come up yourself?, you know my friend jean... said
two things are important for top sound, wideband and symmetry
well i jean.. didnt know that! thanks jean
looks good should sound good
cheers
Old 2nd December 2005, 08:17 PM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi Leolabs,
I can see your feedback resistor getting warm at high levels. Guess inductive types are not recommended?
-Chris
Old 2nd December 2005, 08:26 PM   #5
Howdy! Let me ask: In your second voltage gain stage with the BJT's (just before the MOSFET outputs), what is the purpose of your two 10k resistors to ground?
Old 3rd December 2005, 02:01 AM   #6
Leolabs's Avatar
Yes,I came up Lizi by myself,and she isn't well tuned yet,as she's still on the paper.
I dont see that cascoded JFETs are necessary to be used at the input stage,but I maybe wrong.
The resistors might get warm at high levels,just wondering half watt resistors might do the job or not.
The two 10k resistors at the second stage are local feedback resistors,which are rarely seen.
And I wish that DIY audio topic of year 2006 will be"Lizi vs Gainclone"
Old 3rd December 2005, 02:12 AM   #7
Tim__x is offline Tim__x  Canada
The input stage is unbiased, the amplifier will have massive uncorrected crossover distortion.
Either use JFETs, as MikeB suggested, or add some bias through diodes or emitter followers.
Overall I think you'd be better off with a more standard topology.
P.S. The 10k resistors merely reduce open loop gain, for local feedback they should be connected collector-base .
Old 3rd December 2005, 10:07 AM   #8
MikeB's Avatar
To show the problem/biasing i attached a sim-shot. By using jfets the circuit becomes functional at once, but the jfets needs cascoding because they would not withstand the 40volts.
The 10k resistors are typically a good thing, they flatten openloop bandwidth and reduce zout of the vas.
Leolabs, you might consider getting a sim software, it is the best tool to learn a lot about electronics.
Mike
Old 5th December 2005, 01:29 AM   #9
Leolabs's Avatar
Here is another look of her:
Old 5th December 2005, 01:41 AM   #10
Leolabs's Avatar
The first stage is around 5mA,and the second stage is around 10mA.
Lizi final Leolabs Solid State 1 1st February 2006 02:39 AM
Another look of Lizi Leolabs Solid State 4 7th December 2005 02:49 PM
amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? siu sin man tho Digital Source 0 17th March 2004 12:31 PM
Page generated in 0.10084 seconds (78.47% PHP - 21.53% MySQL) with 11 queries
