Old 2nd December 2005, 10:14 AM   #1
Default 300W Power Amp
Hello !
I Found this schematic in an older Croatian electronic magazine. What do you think about it ? It is suitable for PA or home use ?
Some are born with more and some born with less so don't take for granted the life we've been blessed it's hard to understand thet we're only a guest and each one of us shall be put to life's test.
Old 2nd December 2005, 10:49 AM   #2
From it's complexity I would suggest it's probably intended for home use?, but there's no reason you can't use it for PA - but make sure you use suitably sized heatsinks and power supply components - both of which could really do with being substantial for prolonged high power PA use.
Nigel Goodwin
Old 2nd December 2005, 02:04 PM   #3
I was thinking the same, but the article is saying that this amp is intended for PA use. I'm very curious about the sonic of this amp. Maybe I will build it for test purpose.
Cheers
Old 2nd December 2005, 04:41 PM   #4
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
I've seen PA amplifiers circuits more complex than this one.
The output stage has a 1500 watt power rating, with 60 volt rails that is more than 7 times the continuous power in 8 Ohms.
That and the topology of the output stage with a driver for each output device makes it a circuit designed for PA purposes.
Input filters say so too.
Looks like Sponge Bob has killed another thread.
Old 3rd December 2005, 03:07 AM   #5
CBS240 is offline CBS240  United States
CBS240's Avatar
Overall, looks like a solid design to me, you should go for it. It would be interesting to see what the difference would be if Ic in first diff. was increased to 1mA, and 2mA per leg, and compare the results. Might need a resistor on the collector of current source to absorb some heat and change the two 1K resistors accordingly though.
As for the circuit, any improvements are a plus. You might add a resistor between the emitter of drivers and the base of outputs. Or you could change the three smaller drivers for 1 larger one and use base resistors on outputs and use less parts. I don't see where that would change the operation but then you might need a small heatsink for it. Degeneration resistors on the emitters of the first differential would be OK. With Ic 0.5mA in each leg, maybe like 200 or 300 Ohms?
Oh yeah, a Zobel net wouldn't hurt either.
Anyway, good luck!
All the trouble I've ever been in started out as fun......
Old 3rd December 2005, 04:04 PM   #6
the 39K on the input seems a bit large, try 10k to 20k for an RF filter of 80kHz to 160kHz (-3db).
The gain @ 71times (+37db) also seems quite high for domestic use and very high for PA use.
The output stage should be good for 4ohm use IF you keep the heatsinks cool.
The input time constant @ 73mS is a lot longer than the NFB RC @ 47mS. These could usefully be reversed.
Yes, I agree, add emitter resistors to the LTP and compensate by increasing LTP current. Readjust LTP load to balance the LTP halves.
How about adding a cap to ground for the bases of the input cascodes.
The 100pF compensation cap may need some adjusting to optimise stability, possibly a lot smaller.
The circuit looks promising.
regards Andrew T.
Old 3rd December 2005, 06:28 PM   #7
Thanks for your responses. So you think that this amp with some mods could be used for home amp ? I think that I will build one for test but with +/-50V power supply and with suggested modifications.
Cheers
Old 7th December 2005, 06:07 AM   #8
Any alternatives for the BF470, BF469, BD239
Old 7th December 2005, 06:25 AM   #9
Account Disabled
Hi bostjancek,
You cannot get 300W into 8 ohms from this - the supplies are too low for 69V output. You cannot get 300W into 4 ohm out of this into a reactive 4 ohm load at the protection circuit will trigger at half current (1/4 power) or on only 30deg phase, so would be unsuitable for a sub.
The protection circuit restricts the outputs to 120W each. Also the undegen first and second differentials mean higher THD and the topology looks weak on PSRR.
Whereas my GB300D amp will do 300W into 4 or 8 ohm from +/-55V or 75V respectively.
http://members.dodo.com.au/~gregball/guru_007.htm
greg
Old 7th December 2005, 07:15 AM   #10
three pairs of MJ15003/4 are OK for 4 ohm duty.
Does it matter that 300W into 8ohm is not available?
Recalculate the protection component values and ignore the advertising coming from amp guru.
At least Amp guru also agrees that adding Re is better.
regards Andrew T.
Ohmite 32 ohm 300W rheostat power resistor boywonder Swap Meet 0 31st May 2009 01:37 AM
300W P.A. amp drummer_Dave Solid State 4 19th February 2009 10:45 PM
4 sale or Trade:TAS5261DKD 300w Digital Power amp IC"s!!! Minion Swap Meet 4 18th January 2007 05:05 PM
sam's 300W or eti-466 : power supply bigpanda Solid State 3 1st April 2005 08:17 PM
Page generated in 0.12355 seconds (81.17% PHP - 18.83% MySQL) with 11 queries
