Dear Sirs,
I have a question (maybe trivial but I am quite ignorant) about peak current output for a power amp. Seldom in the specifications I see this value. My question is, does this value dipend mostly on: 1) the type and number of the output devices used or 2) the VA of the transformer or 3) the amount of filter capacitance ? I ask you this because I have an amp with a single pair of 2N5886/2N5884 per channel. How much peak current can I expect from this amp with these output devices? Is there a way to measure it ? Can I replace this pair with something more powerful to get an higher current output? You can insult me if this question is too silly. Thank you very much indeed anyway. Kind regards, beppe61 |
#2 | ||||
Hi
If it has a simple one-bjt protection around output transistor, than the borderline of protecion is Vbe-on-drop (0.7V) divided by emitter resistor of output transistor. If not, then max current is a value on which output transistor explodes. Quote:
Seriosly, one could say that max collector current is a max current of an amplifier, however it is wiser to look at safe operation area ratings to answer at which current and which voltage it can brake. It gives you no simple answer, rather the function of both I and Vce. Quote:
regards |
#3 | |
#4 | |
Personally I would say that the limiting factor (in the amplifier) would probably be the supply reservoir capacitors - it's those that are responsible for delivering short peaks of current. However, it's the load that's responsible for drawing the current, and that would probably be the largest limiting factor (assuming no limiting in the amplifier).
Nigel Goodwin |
#5 |
Electrons are yellow and more is better!
... but only under certain circumstances which you don't have in your case.
/Per-Anders (my first name) or P-A as my friends call me |
#6 | |
thank you so much for your extremely kind and valuable reply. You have hit the center of the problem. My load (speakers) are quite demanding in terms of current. So I wanted to know firstly if the output devices can deliver more current (i.e. they are not a limiting factor). Now I know they can. Secondly, if a filter capacitance increase can be beneficial for peak current. And saying that the supply reservoir caps are responsible for delivering short peaks of current you have completely answered to my question. Thank you very much. So I will start doubling the total capacitance ( from 20.000uF to 40.000 uF) and replacing the diodes bridge with a more stronger one. Then I would like to try another transformer from Talema with more VA, passing from 300 VA to 500 VA. As you can understand I am experimenting a little here. But first the caps. Thank you very much indeed again. Kind regards, beppe61 |
#7 | |
thank you so much for your extremely kind and very valuable reply. Unfortunately your explanation is beyond my ability to understand (I am very ignorant in electronics). Actually I wanted to know if the output devices can deliver more current, and you answered positively. Thank you. So in order to get a certain peak current increase I intend to double the filter capacitance and see, well and hear for improvements in sound. My amp suffers a lack of drive in the part of the spectrum under 100Hz at present. This experiment will not cost me too much I hope. And it could be interesting. Thank you very much again. Kind regards, beppe61 |
#8 |
Hi Beppe,
This is also a good question but it is complicated. Do you have a schematic for the amplifier? Does it have output current limiting protection? It's important to know if the output stage is emitter follower or a CFP. What impedance does your speaker present to the amp? Is it 4 ohm but dips lower, or is it strongly reactive? If you look at the beta or hFE curves for the transistors you might notice that the beta drops at high current, this is called beta droop and was much worse in older transistors. Take a look at the MJ802, an excellent older transistor but it has a lot of droop, or look at the 2N3055. This output current can limit due to a lack of drive, usually in older emitter follower designs. Pete B. |
#9 | |
Dear Pete,
thank you so much for your extremely kind and valuable reply. Unfortunately I understand that the case is much more complex than I thought. > Quote:
By the way leaving all others things as they are now, do you think that doubling the capacitance in the PS could increase the delivarable peak current ? On the basis of your very valuable analysis and remarks I doubt a little now. Are you aware of very easy to build and good schematics (or kits) of low power high current amps ? This value of the peak current is very seldom stated in the specs. And in my case it seems a key parameter. I was lucky with two small but powerful Albarry M408, for instance. They drove quite easily my speakers with a nice sound. Thank you somuch for your kind and valuable reply. Kind regards, beppe61 |
#10 | |
There's no such thing as a 'low power, high current' amplifier, high power and high current go together - it's a simple mathematical relationship 'W=IxIxR'. As has been asked previously, what's the problem with your speakers?, what impedance are they?, and for that matter what make and model are they?.
Nigel Goodwin |
| Peak Current in SMPS | microsim444 | Power Supplies | 6 | 3rd January 2009 03:14 AM |
| SG3525 as peak current controller | jegandren | Power Supplies | 11 | 4th December 2008 03:25 AM |
| 83 rectifier peak repetitive current? | plovati | Tubes / Valves | 1 | 27th June 2007 09:01 PM |
| Peak repetitive forward current?? | Nixie | Parts | 8 | 28th November 2006 04:44 PM |
| Amplifier peak current | YUTK | Solid State | 2 | 14th July 2005 05:51 AM |
| Page generated in 0.13308 seconds (83.18% PHP - 16.82% MySQL) with 10 queries |
