howdy - amplifer problem, channel cutting out
Old 28th November 2005, 04:16 AM   #1
Kolcun is offline Kolcun  Canada
Default howdy - amplifer problem, channel cutting out
Hey folks...
I'm fairly new to electronics and stuff, but have a basic understanding. My problem is (and please don't think I'm coming to this forum just to get people to solve my problems... just didn't know where else to turn...) I have two seperate stereo amps that like to cut out at low volumes. One started like 2 years ago, another just recently. Both older models, early 80's. Can't be the speakers, cause it does it just thru headphones also. Replaced the fuses, didn't seem to be those either.
I'm sure this is a common problem if it's happened to me twice. Since everyone here knows so damn much, maybe you guys can clue me as to what I can do, or what the problem is.
Thanks in advance,
Greg.
Old 28th November 2005, 10:06 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Greg,
The fault is most likely speaker relay contacts. If they aren't burnt, they can be cleaned. They should be dry with no cleaner on them when reassembled. Tap the top of the relay at low volume to check.
The problem may also be another switch or control. So operate each switch and control slowly. The channel may come back or sound very crackly. Use proper cleaners. De-Ox-Id (GC) or Deoxid (Caig). Use as little as possible.
-Chris
howdy - amplifer problem, channel cutting outHide this!Advertise here!
Add sub to a 2-channel amplifer? audioboy Everything Else 4 18th July 2007 09:09 AM
NAD 3020 Channel Problem GhettoSQ Solid State 9 19th December 2006 11:53 AM
T-Amp Channel Cutting Out Diomedian Class D 16 16th February 2006 12:34 AM
N-Channel no bias problem B.I.G Solid State 2 18th October 2004 06:59 PM
CD audio channel problem gmonno Digital Source 0 5th July 2004 02:07 PM
Copyright ©1999-2017 diyAudio
