Old 26th November 2005, 08:14 AM   #1
Default ccs biased output device
Every amplier schematic I have looked at seems to use a constant current source for the ltp and vas but I have never seen them used for biasing the output devices. Is there a reason for this?
To me it makes sense to use it. From a thermal stand point, if the temperature of the device increases, causing the transistor to draw more current through the base, the ccs would compensate and keep the current the same.
Old 26th November 2005, 08:23 AM   #2
try looking a bit further.
There are many VAS topologies that do not use CCS. The Leach clone and Krell clone threads both show this complementary dual LTP with balanced VAS.
Now look at single ended output stages. A few use resistor loading but most use a CCS to improve linearity and efficiency.
Pass is an example but there are very many others.
I think most use a coupling cap to block the DC to the speakers but some use bipolar PSU and then need good DC stability to remove the offset problem.
Good searching
Old 26th November 2005, 07:33 PM   #3
Thanks man! You just made me realize what I have already seen. I reviewed some of Pass's amplifiers last night and seen the ccs.
shunt PSU and output device Stefanoo Pass Labs 3 26th November 2008 10:42 PM
Grid battery biased SE output stages zobsky Tubes / Valves 7 8th July 2007 03:43 AM
Gain Matching Output device ???'s Zero Cool Everything Else 6 10th December 2006 04:56 PM
BJT - how can the output device manage Stormo Solid State 3 3rd February 2003 11:25 AM
output device protection w/zeners pprasse Pass Labs 2 26th June 2001 06:05 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
