Old 25th November 2005, 06:28 PM   #1
Tyimo is offline Tyimo  Hungary
Default Hybrid amp questions
Hi!
One familiar of me built the attached amp, but Iam not realy sure that it is working as it is in the schematic.
Could somebody help me to check the schem for errors?
Greets:
Tyimo
Old 25th November 2005, 07:17 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Tyimo,
Where is the speaker return? Is it a split supply or just 200V? Either way, it doesn't look too stable.
-Chris
Old 25th November 2005, 07:43 PM   #3
nikwal is offline nikwal  Sweden
i'm no expert, but it looks to me like it could work.. but personally I would look around for a better design.. or at least another design..that one looks a tad sensitive to variations in the tubes, it has no feedback (you might want that). hmm But it could'nt take very long to assemble one of thoose..
Old 25th November 2005, 07:49 PM   #4
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Any idea how many 1302/3281s have to be placed in parallel to get enough output current on 100 volt rails ?
Looks like Sponge Bob has killed another thread.
Old 25th November 2005, 07:57 PM   #5
anatech's Avatar
Hi jacco,
I don't think very much drive is available from the tubes. Just think how much feedback through the supply there will be. And you'll never get near the rails. It's just wasted heat.
The input appears to be referenced to -100V, therefore it looks like a 200V single ended supply. The bias will not be stable, long term either.
-Chris
Old 25th November 2005, 08:09 PM   #6
It should, my point was that it only takes a little bit of current and a fast signal to blow the outputs.
Putting drivers between the ECC88 and the output devices, and seperate rails for tubes and bipolars is sensible.
This is a waste of tubes, tube filament powersupply, and heatsinks.
Old 25th November 2005, 08:54 PM   #7
anatech's Avatar
Hi jacco,
Whether we go outside SOA or not depends on many things in this circuit. Heck, the ouput cap could short just sitting there depending on where the midpoint settles down to.
An early output death might be a blessing, something will go sooner or later. I agree though, a waste of materials the way it is.
-Chris
Old 26th November 2005, 08:20 PM   #8
Hi!
Chris: I don't know where the speaker return is and the schem looks a bit strange to me.
I think it has split supply +/- 100V, but I don't understand the grunding point in the circuit too.
I also suspect that the amp is not stable as it is in the schem...
For me the most interesting was the White catode follower in the driver stage.
Greets:
Tyimo
Old 26th November 2005, 10:44 PM   #9
anatech's Avatar
Hi Tyimo,
If you look at the diagram, the input signal is referenced to the negative 100V. This is referenced to ground.
The speaker is either referenced to ground or the midpoint of the supply. Either one is risky with the 100V rating of the coupling caps. The current delivered to the speaker will be coupled to the voltage amp stage. This will not sound very good. It may motorboat.
So, have you heard this?
-Chris
Old 27th November 2005, 02:27 PM   #10
sajti is offline sajti  Hungary
I have the book, which contains this amplifier. Unfortunately there is one mistake in the drawing. There is no -100V. That is the ground. This amplifier works from single +100V power supply. This is the reason for the output capacitor.
So it will works, but there will be problem with the thermal runaway, and with the valve drivers, which are not able to give enough current for the output stage.
So I would use transistor based bias network (Vbe multiplier), and ECC99 in the second stage, with at least 20mA bias. Or driver transistors
sajti
OB 3-way Hybrid ctrevith Multi-Way 16 27th March 2009 10:25 PM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
[Hybrid Amp] Questions about the use of zener diodes Johnix Solid State 30 26th September 2004 08:00 AM
Hybrid nitelite Tubes / Valves 3 21st May 2004 06:51 PM
Page generated in 0.10180 seconds (77.45% PHP - 22.55% MySQL) with 11 queries
