Hi there,
I need a electronic circuit to increase my bass sound. Someone pls help me. Does it got to do with cut-off frequency theory? Thanks |
#2 |
And simple and passive...not exactly what you want...but may be helpfull to someone......maybe.
regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#3 |
Thanks Carlos! i appreciate that alot! thanks thanks.
#4 |
That is a lowpass filter, what you want is a amplified peak between 40-60hz or so. best way to do this is getting a sub with adjustable xo point and bass boost.
#5 | |
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum |
#6 | |
#7 |
#8 |
Hi Bryan,
April 2005 SiliconChip had this "Bass Extender" project which may be of interest. Unfortunately it will cost you to read it all. http://www.siliconchip.com.au/cms/A_104168/article.html Regards EDIT: This link has a bit more info. http://216.109.125.130/search/cache?...icp=1&.intl=us
Greg Erskine |
#9 |
a capacitor of say 0.01ufd in series with a resistor, one end connected to the output of the amp while the other end connects to the feedback point. as for the value of the series resistor you can try a value eqaul to the feedback resistor, you can increas or decrease as you go along.
this will increase bass at a loss of mid and highs, if this is acceptable to you. this is the simplest way i can think of.
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#10 |
Here's a decent solution that gives you complete control over what your circuit will do:
Download the program called filterPro from download.com. Instead of relying on other people's schematics of filters and such, you can make your own. Start off by selecting a low pass filter. You can select you upper rolloff frequency (probably 100Hz or less-depending on your application) and the order of rolloff. The higher the order, the steeper the rolloff and the more complicated the circuit. I would recommend just second order for a bass filter. After this, it will show you a schematic based on your specifications. At the output of the schematic is you bass frequency. From here, you need yet another circuit. You will need a gain section. For this, you can use a simple single ended inverted amp. (google it and you can find basic schematics). In place of the resistor that ties to the inverted output, you would place a pot for volume control. Both of these circuits can use the same op-amp (and on the same chip). I would recommend the LM741 though LM324 or others would suit the application. Just get yourself a 5V steady power supply and you're in business! If this seems like too much work, let me know and I can supply you with an old schematic I've made. ~Aaron |
| I need a bass amp schematic | merickrc | Instruments and Amps | 2 | 2nd April 2009 09:19 PM |
| bass booster | jevincuevas | Everything Else | 1 | 29th September 2008 10:27 AM |
| RealMcTube as bass booster | MPU | Instruments and Amps | 9 | 10th August 2008 06:36 AM |
| need volume booster schematic | prorms | Solid State | 36 | 4th October 2007 08:16 PM |
| RCM DT300/Bass booster question | peterpan | Multi-Way | 1 | 22nd February 2004 12:38 PM |
| Page generated in 0.13501 seconds (80.94% PHP - 19.06% MySQL) with 11 queries |
