A friend of mine is making an A Class amplifier with me( I am more like a supporter
Our main gool is to achive a very good amp that will "kick ***" in very sensitive speakers. We know that we must have very low harmonic distortion from the first watt till the 5th. For now, we got very good results in the AP machine but, we never tested it with the sensitive speakers. We don't know how it sounds, because we are waiting for some parts to the PSU(It's going to be an inovative PSU) and we also don't have the time to work 100% dedicated to the amp. Here is some results of the AP machine : ![]() Later I will post the schematic. First let us test in real life. (maybe this week end) For now I can say that is 2x17W What sugestion do you guys make for an amp like this ? What do you guys think is essential ?
If you want power you must add control |
#2 |
Good test result. Waiting for further information.
#3 |
I just checked the maths and found that 0.002%=-94db So I suppose you are about 16bit equivalent which is pretty good. Are your speakers in the 94db/W to 98db/W or similar? Just awaiting the schematic and sound results.
regards Andrew T. |
#4 |
The speakers have around 96 to 98dB.
The top version as around 100dB. We are dissipating 180W. Good heatsinks are required. Let me introduce some new info. Our PSU is based on this concept: - We now that high capacitance capacitors have lot’s of problems at high frequencies - We also now that lot’s of capacitors lower the ESR. ( parallel capacitors ) - And high capacitance is important, it reduces the oscillations of the PSU and gives you deep bass. Our approach is: +Vcc and –Vcc in different boards but with the ground connected directly(board to board), like a sandwich.(ground in the middle) This is the point reference for the star ground. The capacitor are: ( per rail ) 4x 6,800uF 6x 4,700uF 12x 2,200uF 8x 1,000uF 12x 680uF 34x 330uF 16x100nF This will give aprox. 110,000uF per rail, installed form the bigger capacitance to the smaller. PS: We tested a "proto" board with a LM3886 chip and there's no need for snubber
#5 |
Do you have a photo of this?
I want to see the photos of this Capacitor Bank. Thanks in Advance
Brazilian Tube Amp Builder. |
| Sensitive Fullranges for T Class MkIII | timbudtwo | Full Range | 24 | 15th April 2012 08:19 PM |
| Building sensitive speakers | sifis_samos | Multi-Way | 13 | 24th June 2009 02:52 PM |
| Kit for sensitive bookshelf speakers? | Dan Rotigel | Multi-Way | 1 | 26th July 2008 09:59 PM |
| very sensitive speakers | NED 209 | Full Range | 7 | 15th January 2008 05:54 AM |
| Class D, Which speakers ? | amolan | Class D | 4 | 2nd November 2005 05:50 PM |
| Page generated in 0.08137 seconds (74.76% PHP - 25.24% MySQL) with 10 queries |
