Old 24th November 2005, 07:35 PM   #1
Default Right Channel on my amp doesn't work??
I have a 300W stereo amplifier and my right channel just stopped working all of a sudden. I opened it up and found no visibile problems? anyone else know where to look or look for?
Old 24th November 2005, 07:40 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
I'm afraid we need more info.
Brand, type? Did you party? Did you check the fuses, switch signal, speakers? A pictures speaks a thousand words.
/Hugo
Old 29th November 2005, 03:58 PM   #3
Default Capacitors?
Consider the age/quality of each component in your system from Source to Speaker.
I had a similar problem with my vintage set. I also noticed that the Preamp was heating up more than it used to, so I opened it up. I replaced all of the capacitors in the PreAmp and it totally stopped happening. (Can't change the amp - It is constructed so that I can't get to the Caps in there)
I can't say that this is the problem in your system, but it might be. See the post before this for other possible sources of your problem. Also, try to give us more information to work from in narrowing down the possibilities.
Put amp in chassis, then, right channel doesn't work! ambience exists Tubes / Valves 11 4th August 2008 10:30 PM
Counterpoint SA100 one channel doesn´t work Orgonom Tubes / Valves 3 14th January 2007 04:21 PM
LM2574 + FET =-> doesn't work Danko Power Supplies 2 7th July 2005 07:42 PM
my VRDS 7 doesn´t work! kwen10 Digital Source 2 13th January 2005 10:25 PM
Page generated in 0.07207 seconds (74.97% PHP - 25.03% MySQL) with 10 queries
