Help a newbie choose a DIY amp and cd source for cheap
Old 16th October 2002, 08:48 PM   #11
Miasma is offline Miasma  United States
Originally posted by Equilibrium
Have a look at this amp.
It is on my short list. It will take me some time to work myself up to building an Aleph.
Happy trails.
that looks very doable, how much would the supplies cost to build this be (approximately, chasis not included, but psu included)? of course i would want to build 2. no need for a preamp with stated sensitivities.
i have access to bench dc power supplies, oscilliscopes, you name it. but they are not at my home.
Old 16th October 2002, 08:51 PM   #12
SuppersReady is offline SuppersReady  United Kingdom
SuppersReady's Avatar
Hi Miasma,
Just looking at some prices:
Example of Aleph 3.
Aleph boards (via Harvardian?) $45
Harvardian free Q pack of zeners and smaller transistors
BOSOZ board-stereo (via Old Colony) $20
4*26000uF 75V Caps (ApexJr) for Aleph PSU $28
Output mosfets $15-20
Transformers (Don't know US prices) $?40-50
Caps for BOSOZ $???
No need to populate the boards with the most expensive resistors, etc at this point. If you like the sound, you could upgrade parts later on. Heatsinks from ebay or ApexJr perhaps?
Might push the budget, might not. Having access to all the equipment mentioned will save loads on chassis.
I'll admit I am biased as I've just started ordering parts for an Aleph 5. Whichever route you decide I hope you'll enjoy the journey and the destination (Oops, I'm waxing a little metaphorical).
Have fun,
Paul
Old 16th October 2002, 11:28 PM   #13
Equilibrium is offline Equilibrium
Equilibrium's Avatar
$10 for resistors
$25 for capacitors
$50 for a xfmr
$30 for transistors
$5 for a bridge
$18 for a psb
heatsinks ???? I lean towards salvage $20 ???? your call
maybe $40 for wire, solder, diodes, beer, fuses, switches
totals about $200 plus 25% just cause chaos rules
and your looking at $250 easy as key lime pie.
Do you like key lime pie?
I like key lime pie.
A girlie girl is in my kitchen as I type
making key lime pie.
Life is good.
Old 16th October 2002, 11:39 PM   #14
so i should expect about $250 for each channel?
so, around $500-$600 for the entire built amp with PSU?
is there a better deal than this anywhere?
Old 17th October 2002, 12:04 AM   #15
paulb is offline paulb  Canada
You won't find a DIY amp in your price range that is cheaper than a commercial unit. Don't do this to save money. Especially if your time is worth anything.
"wire, solder, diodes, beer, fuses, switches" all add up. Beer? Sounds like a great idea.
Old 17th October 2002, 12:22 AM   #16
time is of little importance here. i want the satisfaction that i built my own amp. it seems i simply cant afford an aleph, knowing that, are there any other designs in the same price range ($700) as the design that i mentioned i lied, that will work any better?
Old 17th October 2002, 12:57 AM   #17
Taligent is offline Taligent
Taligent's Avatar
Another well-reviewed amplifier is the 55w AKSA from www.aksaonline.com.
AKSA review: TNT-audio.com
AKSA forum: Harmonic Discord
Cost with power supply should run around $300 USD or so - it's next on my build list.
HTH,
Nikhil
Old 17th October 2002, 01:52 AM   #18
no sir, $250 for both channels and the psu.
damn this pie is tasty
I kid you not.
Old 22nd November 2002, 03:00 PM   #19
fredsal2 is offline fredsal2
deleted
Fred
Help a newbie choose a DIY amp and cd source for cheapHide this!Advertise here!
Cheap source for unclad FR4? gmikol Parts 2 4th May 2007 12:36 PM
new source for cheap heatsinks? SQ Kid Chip Amps 4 11th March 2005 06:41 AM
So many choices help a newbie choose. Richie V6 Subwoofers 11 16th February 2005 02:57 AM
Source for cheap caps >10000uF, 80V ? Freddie Parts 2 22nd November 2004 07:18 AM
