just repaired a Pioneer M25, the failure was in the rail regulators. On power up there was an initial offset of 0,5V on one channel that faded away after warm up. Now one heatsink gets slightly warmer than the other. There are 4 pots each channel and I do not know what to do with them... Anybody have an idea or schematic please ?
#2 |
hi,
I had saw the M25 sch.IIRC,each channel of M25 has two pots which is 100 Ohms for adjust the protect current,and one pot for adjust the offset .....like the KRELL KSA100 sch. If you research the KRELL KSA100 sch,and trace the M25...I think you can easily find the pot for adjust offset. |
#3 |
What has the M25 got to do with Krell ??? Same ?
There are 4 pots... |
#4 |
My scanner is worse....I just check my paper,the 4 pots is :
VR1(470 Ohms) for adjust offset VR2(220 Ohms) for adjust the idle current of power stage VR3 and VR4(all 100 Ohms)for adjust the limited current of pretect circuit. I can't see your attachment.there are some M22 pictures which the brother of M25,M22 is class A,M25 is class AB. good luck X.G. M22 pictures http://amp8.com/sub/tr-amp/pioneer/pi-m22.htm ![]() KSA100 schematic PCB layout for Krell KSA100 |
#5 |
Thanks,
VR1(470 Ohms) for adjust offset VR2(220 Ohms) for adjust the idle current of power stage VR3 and VR4(all 100 Ohms)for adjust the limited current of pretect circuit. This is from M25 ? M25 board looks different from M22. Also it seems M22 does not use ringemitter transistors, 4 different output 2sa / 2sc devices... What I have read is that M25 is class A up to 30W and B up to 120W. |
#6 | |
#7 |
Ok, I will try.
As you have the schematic... There is a zener diode in the regulators, it was dead and I can not identify it. Can you see the type ? 30 V ? 33V ? Thanks. |
#8 |
#9 |
Left and right are identical.
Looks like Sponge Bob has killed another thread. |
#10 | |
Not sure but I think it is like marked now in the picture. |
| How To Adjust Bias Current? | Bushulo | Pass Labs | 1 | 14th July 2008 03:11 PM |
| Krell KSA 80 bias & dc offset check & adjust procedure | Clouseaupte | Solid State | 3 | 9th August 2007 10:39 AM |
| Adjust FOcus Offset | Mikelo | Digital Source | 2 | 23rd February 2005 03:24 PM |
| How do I adjust amp bias? | fotzepolitic | Solid State | 29 | 22nd January 2004 06:09 AM |
| Adding offset adjust to Anthony's sym amp | naula | Solid State | 1 | 3rd February 2003 11:27 PM |
| Page generated in 0.09257 seconds (87.49% PHP - 12.51% MySQL) with 11 queries |
