Old 4th June 2010, 06:32 PM   #21
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
C5 and C39 are there to dampen the diode across base-emitter of Q1.
You likely know already that the other three can go if your source doesn't contain DC.
Looks like Sponge Bob has killed another thread.
Old 6th June 2010, 05:47 PM   #22
Bernhard's Avatar
Which other three can go ?
Any suggestion how to get rid of C1 C2 C38 & C5 C39 ?
The source is transformer coupled so no DC, but resistance to ground.
Which means, if i short the input caps and the adjusted input DC offset is not exactly 0V, the parallel Transformer will pull the adjustment somewhere else.
I tried and the result was 2V output offset and the amp going into protection.
C5 and C39 to me look like AC coupled feedback loop, 10n bypass same like on the input.
How To Adjust Bias Current? Bushulo Pass Labs 1 14th July 2008 02:11 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
Adjust FOcus Offset Mikelo Digital Source 2 23rd February 2005 02:24 PM
How do I adjust amp bias? fotzepolitic Solid State 29 22nd January 2004 05:09 AM
Adding offset adjust to Anthony's sym amp naula Solid State 1 3rd February 2003 10:27 PM
Page generated in 0.05777 seconds (67.94% PHP - 32.06% MySQL) with 11 queries
