Old 20th November 2005, 01:18 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Question MOSFET power amp schematic
What's your recommendations,esp for use with the old 2SJ50/2SK135???
Old 20th November 2005, 10:32 AM   #2
edl is offline edl  Hungary
edl's Avatar
Dear Laolabs,
A schema attached.
If you have any question about the schema, let's ask.
Old 21st November 2005, 05:16 AM   #3
Default MOSFET power amp schematic
How dose this amp sound? Any idea?
I want a 20w class A mosfet amp with this output pair; does it work or not?
thanks
Old 21st November 2005, 10:58 AM   #4
djk is offline djk
djk's Avatar
200W into 8 ohms.
http://img.photobucket.com/albums/v3...craftsmen2.jpg
Old 21st November 2005, 11:26 AM   #5
johnnyx is offline johnnyx  United Kingdom
Have a look in this thread. Take note of the issue with the 100 ohm gate stopper resistors, I had a problem with this that was described towards the end of the thread, increase them to 200 ohms or so. This also applies to the Exicon replacement devices;- same problem.
Old 21st November 2005, 01:54 PM   #6
Leolabs's Avatar
Thanks all for your replies.But I have build that with differential amp base input,which I believed taken from Hitachi's application notes.What I am looking for is kind that fully complementary,without differential amp,and yet simple enough with maybe 6 to 8 devices per channel,but definitelly not a single-ended one
Old 21st November 2005, 02:46 PM   #7
Rick NL is offline Rick NL  Netherlands
Look at the Zenquito from mr Plantfeve at http://perso.wanadoo.fr/jm.plantefeve/sche.html
With one set of output devices and 2 x 18 VAC (2 x 25 VDC) it should be a perfect solution for your requirements.
Six devices total and about 25 Watt's in 8 Ohm.
Haven't build this one so I cannot say anything on how it sounds, but I have read good reviews.
Succes,
Rick
After all it's the music
Old 21st November 2005, 03:14 PM   #8
As a remark to my post I might say that with a 2 x 15 VAC (2x 21 VDC) the dissipation on a single output pair would be more at the safe side. Still around 16 Watts in 8 Ohm.
Rick
Old 21st November 2005, 04:11 PM   #9
bear's Avatar
Fully complementary?
DC coupled?
Borbely.
http://www.borbelyaudio.com
also articles published in TAA/Audio Express and in Euro publications too.
_-_-bear
PS. plus they sound and measure well too.
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 22nd November 2005, 01:26 AM   #10
Leolabs's Avatar
Thanks Rick for the website .Thanks Bear for the Borberly,but Borberly's circuits are quite complex,and I really dont want any differential amp input.
Anyone have a schematic for the old Borbely 60W MOSFET Amp jwv3 Solid State 5 26th April 2009 02:21 PM
P channel Mosfet switch schematic bart_dood Everything Else 2 18th March 2009 07:53 PM
Power 300 Mosfet schematic ? Scanlines Car Audio 4 7th January 2009 01:06 PM
Does anyone has mosfet PP power follower schematic? bogdan_borko Solid State 0 11th December 2005 08:37 PM
looking for basic MOSFET amp schematic jude ward Solid State 8 5th January 2002 05:16 PM
Page generated in 0.09989 seconds (76.08% PHP - 23.92% MySQL) with 11 queries
