Adcom 565 Bias - Issues - Need help
Old 20th November 2005, 07:11 AM   #1
Yukonsc is offline Yukonsc  United States
Default Adcom 565 Bias - Issues - Need help
Hi - Have a question I need your guys help with...
I am trying to set the bias on an Adcom 565 and I get 0 -1.5 mv across the terminals. However if I hook a speaker to the outputs the meter goes to 50mv (Also the POT seems to have little to no effect). Still plays music though...go figure
as a side note I set the bias just fine on the other 565 I have - Thoughts? I have the service manual - but am lost at this point. I am just starting in on the repair world.
Thanks in advance.
Old 20th November 2005, 03:58 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Yukonsc,
If you disconnect the speaker from the output terminals, what is the DC voltage across the terminals? The inputs should have shorting plugs installed when you do this, or a know low impedance source with zero signal.
-Chris
Old 21st November 2005, 05:16 AM   #3
Chris -
I'll test it in the morning. Do you mean DC voltage across the speaker terminals? or Bias Test Points?
The Bias Test Points is 0mv (No speaker)
50mv (with Speaker)
I'll measure the DC voltage across the speaker terminals in the morning
Also - What do I short out with a shorting plug - to the point what is a shorting plug?
-Dallas
Old 21st November 2005, 05:40 AM   #4
EchoWars is offline EchoWars  United States
EchoWars's Avatar
Shorting plug = Device that shorts center conductor of RCA jack to ground. Many receivers/preamps that had more than one phono input provided a pair of shorting plugs for the unused phono input.
Old 21st November 2005, 03:25 PM   #5
anatech's Avatar
Hi Dallas,
That tells me you either have an offset problem, or the amplifier oscillates with a load.
Either fault requires work on the PCB. We know you have a meter, how about an oscilloscope?
-Chris
Old 21st November 2005, 10:36 PM   #6
Chris - I used a shorting plug and tested again just to make sure. I got 0v across the terminals again.
Are you prepared to be shocked... I do have an oscilloscope. Its a dual trace 100mhz scope. I do need a little (well alot or just specific) guidance in how/what to test.
thanks again. I am learning by doing...
-Dallas
Old 21st November 2005, 10:36 PM   #7
Chris - I meant to mention - I replaced all the electro. caps on the driver board already - The caps were leaking. I followed the repairs suggested on this site
http://www.angelfire.com/art2/stereorepair117/adcom.htm
(I replaced just the caps not the driver board transistors)
However the problem was present Before the repairs. That is what prompted me to to start this journey.
thanks again for your help
-Dallas
Old 21st November 2005, 11:00 PM   #8
anatech's Avatar
Hi Dallas,
So you are saying that the voltage across the output terminals is close to 0V, less than 50mV? Set the bias current the same as you did.
Set your oscilloscope for 20V/div. Now, connect you oscilloscope lead to the red output terminal. If you get a large 60 Hz component, connect the ground to the chassis, or black terminal. The trace should be sharp (thin, don't turn it up extremely bright). Connect a speaker while watching the waveform. If it gets thick, the amp is oscillating. You may have to turn the vertical sensitivity to a lower setting, say 5 V/div.
If this is the case, check the zobel network (R-C across the output).
What did you clean the PCB with?
-Chris
Old 21st November 2005, 11:40 PM   #9
Chris - Thanks again...
I measured 0mv across the output terminals. Currently the amp and scope are not in the same place. I'll try and get that sorted in the next day or so and follow your directions.
I cleaned the board with a generic pcb cleaner - nothing fancy. The caps didn't look like they were leaking to bad - just smelled really bad when I un soldered them.
I'll do some homework on the Zobel network and see if I can figure out where it is located on the board.
Stay tuned
-Dallas
Old 21st November 2005, 11:46 PM   #10
anatech's Avatar
Hi Dallas,
To clean a PCB, I normally use "electrowash 2000" and a toothbrush. I may use an aqueous cleaner and toothbrush, removing pots first. Then I let the board dry a few days, typically I shake it and warm blow dry it right after the wash.
-Chris
Adcom 565 Bias - Issues - Need helpHide this!Advertise here!
2 Adcom 565's with issues Ardvaark Solid State 28 4th August 2012 05:48 PM
Adcom GFA-555 bias? joad Solid State 7 13th May 2007 03:02 AM
hh scott bias issues cwerner Tubes / Valves 3 14th April 2006 06:41 AM
Adcom GFA535 bias adj. ostie01 Solid State 0 22nd January 2006 12:49 AM
How To adjust Adcom 565 Bias HiFiMonk Solid State 1 25th November 2005 12:09 AM
