New Naim Output Transistors - Page 7 - diyAudio
Old 27th November 2005, 04:02 PM   #61
EUVL is offline EUVL  Europe
Hugh,
How is your own experience with Peacock ?
These days there are so many transistors around from unknown sources with the same part number printed that I never know for sure unless they come from a Toshiba distributor.
And unfortunately their distributors in Europe do not stock JFETs and limited MOSFETs. : (
Patrick
Old 28th November 2005, 07:08 AM   #62
Ultima Thule's Avatar
Originally posted by AKSA
Hi Luke,
Ah, not these guys - they are in Canada and quite a bit dearer!!
Try
http://www.peacock.com.sg
Hugh
Hi Hugh,
I remember we actually exchange couple of words here on diyaudio for a long time ago about peacock.
As per your words they are trusted but I remember the issue with them was that one have to make quantity ordering, don't know what the minimum amount would be, Hugh?
Cheers Michael
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears"
Michael 29th January 2010
Old 27th December 2005, 05:14 PM   #63
etsang3 is offline etsang3  Hong Kong
Hi, i would like to let all you know that I have changed a Nait-2 O/P power transistors to complementary pair ON Semiconductor MJE15032 and MJE15033 (with some circuit modification) and the amp sound much better) http://www.onsemi.com/PowerSolutions...do?id=MJE15033
Old 12th January 2006, 02:25 PM   #64
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
return to the topic, there is another rather new 350W TO-3 device, but only 40A peak and double die:
http://www.onsemi.com/pub/Collateral/MJ21294.PDF
Old 13th January 2006, 06:16 AM   #65
Workhorse's Avatar
Dimitri, but its still very little thing in comparision with what we have in the domain of vertical mosfets...
K a n w a r
Old 13th January 2006, 01:53 PM   #66
dimitri's Avatar
Let us compare SOA and the cost, which is $5.7 for this device, and yes, it is slow
Old 14th January 2006, 12:06 PM   #67
Workhorse's Avatar
Ok just take cost comparision, still vertical N-channel mosfets are still cheaper and faster than this bipolar....
Old 3rd June 2012, 05:57 PM   #68
tiefbassuebertr's Avatar
Originally Posted by Charles Hansen View Post
Thanks for the info. Semelab is a small UK-based foundry that is willing to do specials and custom parts. (They are the ones who make the Exicon and Magnatec lateral MOSFETs.)
According to the Naim website:
http://www.naim-audio.com/products/nap250.html
"The NAP 250 uses the same 007 transistors that were custom-designed for the NAP 500. These outstanding components each provide up to 80 amps and 350 Watts, negating the need to use parallel pairs of transistors (which always have a negative effect on sound)."
Interesting informations - thank you
Naim PC boards and Sanken power transistors for sale gaborbela Swap Meet 2 16th November 2008 05:09 PM
output transistors pezza89 Vendor's Bazaar 0 2nd November 2007 11:14 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 01:06 PM
Output Transistors weinstro Parts 1 9th May 2003 12:51 PM
Which power transistors for Naim amp hifileslie Solid State 1 18th May 2002 10:35 PM
Copyright 1999-2017 diyAudio
