New Naim Output Transistors - Page 3 - diyAudio
Old 21st November 2005, 05:46 AM   #21
jam is offline jam  United States
jam's Avatar
how come you are so keen to BJT output tranies, should it not be lateral FET's to make you post, or are we seeing Ayre with BJT's in the output soon?
................................only the Shadow knows!
Jam
Old 21st November 2005, 11:17 AM   #22
lohk is offline lohk  Europe
lohk's Avatar
NAP250 uses -001 transistors in TO3 package (a special BUV20 made by Semelab)
NAP500 uses -007 transistors in TO3 package (also made by Semelab)
NAP150 uses SANKEN 2N2922 like the discontinued NAP140
quote Julian Vereker (in HIFI+ #4/99) about the development of the NAP250:
"... I wanted a transistor which was very fast (rather than necessarily linear), without any storage time especially at low currents, and I wanted it to turn off at low currents. ..."
/lohk/
Old 21st November 2005, 11:18 AM   #23
lohk's Avatar
the -007 transistor very likely is the Semelab BUX20
http://www.semelab.co.uk/pdf/bipolar/BUX20.pdf
/lohk/
Old 21st November 2005, 02:11 PM   #24
Only the Shadow and about 1,000,000 other people. For example, see:
http://www.soundstage.com/revequip/ayre_v5x.htm
where it is revealed "So when Hansen designed the V-5, he used FETs in the input stage and bipolar output transistors at the output -- 16 of 'em in each channel."
Old 21st November 2005, 02:43 PM   #25
jam's Avatar
......................oops!
Old 21st November 2005, 02:51 PM   #26
Thanks for the info. Semelab is a small UK-based foundry that is willing to do specials and custom parts. (They are the ones who make the Exicon and Magnatec lateral MOSFETs.)
According to the Naim website:
http://www.naim-audio.com/products/nap250.html
"The NAP 250 uses the same 007 transistors that were custom-designed for the NAP 500. These outstanding components each provide up to 80 amps and 350 Watts, negating the need to use parallel pairs of transistors (which always have a negative effect on sound)."
Old 21st November 2005, 03:13 PM   #27
That's a different NAP250 to the one pictured up-thread, FWIW. Only the name(!) remained the same.
I have a mid-70s NAP250, which is a similar design to the one pictured up-thread but a different case style and circuit arrangement and that's fitted with 8 BDY58s. FWIW.
Paul
Old 21st November 2005, 03:27 PM   #28
lohk's Avatar
Naim changed the output transistors for the 250 in the late 70ies (aprox.) from BDY58s to the mentioned 001 propriate designs. Since then the classical 250 used this transistor. The new 250 is another story, using different regulators and amp inputs AFAIK.
/lohk/
Old 21st November 2005, 03:36 PM   #29
lohk's Avatar
I have very good experiences using the Cyrus PT7 (TO-220, BUV28?) and PT77(TO-247, another switching transistor?) in Naim clones. The smaller amps can use the BD911 or like other smaller Naim amps the BD743 (the NAIM NA-005). The older version of the NAP110 used the BUV20.
/lohk/
Old 21st November 2005, 04:44 PM   #30
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Some may wonder what those 16 high-current bipolars might be, 007s as well ?
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Naim PC boards and Sanken power transistors for sale gaborbela Swap Meet 2 16th November 2008 05:09 PM
output transistors pezza89 Vendor's Bazaar 0 2nd November 2007 11:14 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 01:06 PM
Output Transistors weinstro Parts 1 9th May 2003 12:51 PM
Which power transistors for Naim amp hifileslie Solid State 1 18th May 2002 10:35 PM
Copyright ©1999-2017 diyAudio
