I have this Yamaha receiver where the relay circuitry is acting up and not allowing the amplifier to function.
Anyone have the schematics of this? Thanks Tom |
#2 |
Hi tmblack,
What's happening exactly? BTW, Yamaha loves to use lamps in muting and protection circuits. If there are any burnt out, replace them and your problem may go away. Sorry, no longer have that manual. -Chris |
#3 |
Sometimes the unit turns on after a very long wait and the relays make a click, then it might make a loud crack and the unit goes off again.
Maybe there is a leaky capacitor or dc offset? Not a bad looking unit for the late 70's, I'd like to fix it. Tom |
#4 |
Hi Tom,
Sounds like an offset problem all right. It is a good rcvr. If I'm not mistaken, that unit uses an STK voltage amp, doesn't it? If so, I'll bet that's gone bad. You can try resoldering the pins first. Clean off the old solder and use flux. -Chris |
#5 |
No, it actually uses all transistors in the amplifier.
Any idea how the relay circuit works? Tom |
#6 |
Hi
Go to www.stereo411.com/forum and ask Age for the Yamaha CR-820 service manuals, if he hasn't the schematics , write u'r e-mail address and i sent u the CR-1020 or CR-620D Regards Dudu
#7 |
Start by replacing the cap on the base of TR804, then the caps on the base of TR704, TR705 to ground.
There may be other problems. http://www2.yamaha.co.jp/manual/pdf/...AFR/CR-820.pdf |
#8 |
Hi djk,
Thanks for the link, I can almost make out the numbers. Tom, Look to see if there are bad solder joints. They will look frosty rather than smooth now, there may be a tiny black ring around the component lead. Remove the old solder, add flux and resolder. Don't use too much solder (avoid leaving solder blobs). Clean the PCB with lacquer thinner and look for solder wiskers when you are done. Replacing the electrolytic caps as djk suggested may improve the sound quality at this age. -Chris |
#9 |
Wow,
thanks for the links guys. I am very impressed! Yes, I will replace those caps and look around the board. Do relays usually need replacing after a couple od decades? Tom |
#10 |
It's not likely to be the relay.
The relay drive circuit has an RC time constant before it latches, that is the first cap I want you to replace. The drive circuit also senses DC and cuts the relay off. The second set of caps I listed can affect DC off-set. As Chris pointed out, the loud noise when it cuts out is probably DC. The DC could be from many things. IIRC, TR713, TR714 run hot and the solder joints can go bad. It could take some time to actually find the problem. |
| Yamaha equalizer eq-70 schematics | lduarte1973 | Parts | 0 | 2nd March 2009 06:29 PM |
| Yamaha Rx-S70 schematics | ledoo20 | Solid State | 2 | 20th February 2009 01:40 AM |
| Yamaha M-80 Schematics | dcvvs | Solid State | 16 | 11th September 2007 04:08 AM |
| Yamaha M-80 Schematics Please O Please! | bluesmoke | Solid State | 6 | 25th April 2006 07:37 AM |
| Looking for schematics... Yamaha M-70 | akguzzi | Solid State | 0 | 2nd August 2005 06:29 PM |
