If i wanted to load a pair of push pull source followers with a transformer similar to the susan parker design... how do i determine what primary inductance is needed and with a particular output impedance of the source followers what should the load on the secondary of the transformers be?
Is there a good website that explains this? what is output impedance of a source follower mathematically? thanks!
It is not you... you are it. |
#2 |
1/gm for small signal analysis
gm = (2 S Kpn Ids/n)^0.5 if memory serves at least. but those specs probably aren't available. not sure how to mathmatically get them. maybe test it out with a common gate amplifier. of course this doesn't count feedback which can lower output impedance.
if only it could be used for good, not evil... |
#3 |
I wonder if you could use a toroid trans, but drive the CT secondary with the push pull, and either wind your other side yourself, for speaker impedance, or use the 120V primary to get a HV output to get either really loud speakers, or use on 70V line trans.
| Changing input impedance of a source follower? | JoeBob | Solid State | 10 | 1st February 2011 02:46 PM |
| optimum load for mosfet source follower? | AudioGeek | Solid State | 2 | 11th February 2006 08:45 PM |
| how to determine optimum load for source follower?? | AudioGeek | Solid State | 0 | 22nd January 2005 08:27 PM |
| load on source follower choke or mosfet? | AudioGeek | Solid State | 57 | 2nd September 2004 03:42 AM |
| Page generated in 0.07388 seconds (81.32% PHP - 18.68% MySQL) with 10 queries |
