Yamaha RX-V490.. Tuner problem - diyAudio
Old 14th November 2005, 08:05 AM   #1
Default Yamaha RX-V490.. Tuner problem
I have a Yamaha RX-V490 Reveiver and about two weeks ago, the FM tuner went bad. Now it goes from 76MHz to 90 MHz (I believe Japanese range) instead of 87.5 to 107.9 MHz (US range).
Does anybody have an idea what could be wrong? Also, is there any possibility to find a service manual for this model?
Any advice will be most welcome!
Thanks in advance.
Old 14th November 2005, 10:31 AM   #2
dudu is offline dudu  Israel
Adress........?
Dudu
Old 14th November 2005, 02:53 PM   #3
Thanks.. I don't know if you refer to e-mail address or physical address.. Following are both..
e-mail : tharaka@bellsouth.net
Home:
Tharaka Goonetilleke
2990, White Cedar Circle,
Kissimee FL 34741
USA
Old 3rd September 2007, 03:43 PM   #4
q2audio is offline q2audio  United States
Default RX-V490 Tuner Problem
I have the same tuner problem with my RX-V490. It will only tune the Japanese band. Please let me know how I can fix this.
Thanks!
Tim
Old 5th September 2007, 11:41 AM   #5
aman is offline aman  India
aman's Avatar
hi all
i have got a technics tuner and its frequency band is only 76-90 mhz. could i make some changes to increase the range to get indian stations(87-108mhz)?????. I have another tuner of Yamaha (dont remember the model) its range is 87-108mhz but it doesnt play any station, may be theres some problem in the front end or anywhere else,the output is only a hissing sound.
I think the microprocessor unit in 76-90mhz band is programmed for a selected band only and little can be done to increase the range and it would need a drastic re-engineering to get the universal range.
any sort of help is appreciated.
aman
Old 5th September 2007, 12:24 PM   #6
Default RX-V490 SM
I tried to send You the SM, but your email-adress doesn't respond.
So I uploaded it at http://fileshare.eshop.bg
I hope this will help You
Michael
Old 5th September 2007, 12:57 PM   #7
Westley is offline Westley  United States
The tuning problem may be caused by a component failure or corrupted data. Most likely, this can be corrected by performing the factory initialization. Press the PHONO and CD buttons simultaneously, then press the POWER switch. This begins the test mode. Press EFFECT button to exit to go back to the factory set specifications.
If that does not restore the tunig to the US band, the microprocessor IC301 may need replacing. Good luck.
Old 5th September 2007, 08:47 PM   #8
Thanks guys! I'll give it a shot asap.
Tim
Yamaha RX-V490 Amp Problem har2k Solid State 22 26th January 2012 11:57 PM
Yamaha T-85 Fm tuner mods. pdul Solid State 7 10th August 2010 04:24 PM
Need helps with a Yamaha digital tuner gaetan8888 Analogue Source 2 27th January 2009 02:17 AM
Yamaha T80 tuner jean-paul Solid State 3 23rd May 2003 08:06 AM
DIY FM Tuner - what's the problem? jackinnj Solid State 3 26th April 2002 08:49 PM
Copyright 1999-2017 diyAudio
