What do you think about this preamp? Do I need to add a output stage with more current capacity, or will this do as a preamp? I was thinking of using it as an ubalanced to balanced preamp. Please give comments. It's a differential pair with CCS. Power ground is seperated from signal ground through a low value resistor. |
#2 |
you have posted two single ended single transistor common emitter amps. I think you will find problems setting the DC level and holding it. There appears to be no gain setting for either AC or DC. Have you thought about frequency response anomalies? I think you would be better off looking at the various (many) discrete opamps around the web. Most of them could be adapted to balanced in/out.
regards Andrew T. |
#3 |
Thank you for responding.
The DC is taken care of by the output caps, and the circuit does have AC voltage gain. I just want to build a unbalanced to balanced preamp because all my sources are unbalanced, and I want to build a balanced power amp. Any good sounding DIY designs you (or other) could recommend? BOSOZ may be a good candidate... |
#4 |
Can you send the complete schematic with the values of the components?
I realy like this design! Thanks in advance. Felipe Navarro.
Brazilian Tube Amp Builder. |
#5 | |
Where is the control for your AC and DC gain? or is it completely dependant on hFE (Hfe) of the device?
regards Andrew T. |
#6 |
The resistor between the emitters controls the gain, toghether with the collector resistors. However, I would suggest the more traditional diff pair topology, with one CCS and two emitter resistors, because now you must match the two CCSs, which is more work than to just match two emitter resistors. Of course, the BJTs in the diff pair must be matched in both cases.
#7 |
Was afraid of having to match the CCS.
Maybe the BOSOZ with a CCS is a better solution? |
#8 |
But why use two in the first place? Split R1 into two resistors with half the value and use one CCS with twice the current.
#9 |
The reason for two was symmetry and lower temperatures in the transistors.
| Matching BC550C BJTs | lgreen | Solid State | 8 | 3rd September 2009 04:21 PM |
| MPS8099/MPS8599 vs: BC550C/BC560C | Dick West | Solid State | 14 | 22nd May 2005 06:29 PM |
| bc550c and bc560c | Wagener | Solid State | 19 | 10th May 2004 03:27 AM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
| Page generated in 0.08936 seconds (74.98% PHP - 25.02% MySQL) with 11 queries |
