Old 10th November 2005, 11:27 PM   #1
Account Disabled
Default 300W 'modulated bias' cascode Killer Amp
Here is the first pic of the 300W version of the simple Killer Amp.
The complementary differentials are cascoded allowing the same Ft > 200MHz, Hfe > 450, 65V transistors to be used for inputs diffl's and driver/buffer with 4 pair of matched IRF complementary MOSFETs.
The cascode BJTs are biassed from a divider in the following driver which is modulated with the driver signal out of phase with the input/feedback signal to the differentials. This reduces THD by 2 to 3 times over a standard biassing arrangement.
I stll haven't bought that better camera.
Greg
Old 11th November 2005, 03:37 AM   #2
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Guru , I think a schematic would be a better option than this photograph
Cheers
K a n w a r
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 11th November 2005, 04:31 AM   #3
sam9 is offline sam9  United States
sam9's Avatar
Ditto. Your digital camera has even crappier resolution my mine.
Old 11th November 2005, 05:04 AM   #4
Account Disabled
Hi Kanwar, Sam 9.
OK,OK I'm shopping for a camera tomorrow! They let me out on day release Saturdays.
Here's the topology.
http://members.dodo.com.au/~gregball/guru_007.htm
Full schematics come with the kit.
Greg
Old 11th November 2005, 05:15 AM   #5
Workhorse's Avatar
Ok Greg,
Purchase a digital Camera with "OPTICAL ZOOM" only , donot take digital zoom instead of it, because optical zoom is much clearer than digital zoom, after all optical zoom is another form of image amplification....
regards,
K a n w a r
Old 11th November 2005, 05:52 AM   #6
Electrons are yellow and more is better!
peranders's Avatar
Just wondering, but don't you get a rather high output impedenace when you have drain out?
The distortion is reduced you say by 2-3 times, from what?
/Per-Anders (my first name) or P-A as my friends call me
Old 11th November 2005, 06:04 AM   #7
Workhorse's Avatar
This line made me laugh out of Hell......
"You work for small outfits, and can do weird stuff because there is no one there to keep you under control"
Peranders, Is this really from one of the 29 commandents of Jocko Homo......HAHAHAHAHAAAA
What:?
Lots of Signatures PA
Old 11th November 2005, 06:16 AM   #8
peranders's Avatar
Word by word by the Great One from Texas. Nothing added or removed.
Old 11th November 2005, 06:37 AM   #9
Account Disabled
HaHaHa
I resemble that remark.
Peranders,
THD is 2 to 3 times lower than with a conventional fixed bias cascode. More to come.
The Zout should prove even lower than the smaller 2 o utput pair Killer Amp as the doubled output stage will have 2 x transconductance so 2 x voltage gain, so 2 x NFB, so 2 x lower Zout !
Greg
Old 11th November 2005, 06:45 AM   #10
peranders's Avatar
Have you verified your claims about the dist? From what to what? 0.0046 to 0.0023% or 0.3 to 0.1%?
The modulated supply and voltage swing (patent #5,343,166) rtarbell Pass Labs 13 25th April 2006 02:50 AM
Modulated cascode and positive feedback? Circlomanen Pass Labs 4 13th March 2006 01:14 PM
Direct Coupling Modulated Bias (SET) serengetiplains Tubes / Valves 59 10th February 2005 08:28 PM
MODULATED lobing and response Bill Fitzpatrick Multi-Way 43 2nd March 2004 10:58 AM
resistor vs. fet single, or cascode opamp bias? crippledchicken Parts 0 20th December 2003 07:26 PM
Page generated in 0.10069 seconds (78.68% PHP - 21.32% MySQL) with 11 queries
