300W 'modulated bias' cascode Killer Amp - Page 5 - diyAudio
Old 11th December 2005, 03:02 AM   #41
jcx is online now jcx  United States
a quick sim of a "half cell" suggests a fair amount more gain can be had by using a cfp for your follower - mosfet bias permitting, but probably hopelessly complcates overload behavior
Old 11th December 2005, 04:50 AM   #42
Account Disabled
Hi jcx,
A CFP instead of the BC546C? The gain's huge already, believe me.
" probably hopelessly complicates overload behaviour" - as it is I've had to put in a clamp diode to stop the base collector forward biassing and switching on the MOSFETs at clipping on the off cycle.
greg
Old 15th December 2005, 04:00 AM   #43
Account Disabled
Just as a matter of interest I decided to sim my design with a Leach cascode front end (pictured below) to check for PSRR. This can be compared with my cascode front end at post 40 -
http://www.diyaudio.com/forums/showt...965#post786965
Greg
Old 27th December 2005, 12:41 AM   #44
Account Disabled
Well Hi all,
Between festivities and libations I decided to build a new piece of test equipment to test my amps - a 10KHz tailored impedance square wave generator. I needed one which had sufficiently fast rise time and worked into a capacitative load, so I could bypass the Rinput filter and test closed loop character. A very fast rise time better stimulates the UHF character of an amplifier.
Spec : 10KHz, rise time < 400nS , fall time < 100nS. Zout 47R //1000pF.
Here is the GB300D with it's output . no 160KHz input filter.
Greg
Old 27th December 2005, 01:19 AM   #45
Banned
Greg top performance mate! you should publish it at stereophile.com
happy festive season mate
Old 27th December 2005, 01:39 AM   #46
Account Disabled
I think not mastertech,
Interestingly the rise and fall times are virtually those of the square wave generator... so I guess I'll need to do an even faster one.
That's the trouble with building really fast amplifiers, in this case full gain bandwidth >5MHz, is that your equipment has to be upgraded as well.
Perhaps I should stick to ordinary amps in pretty boxes and high bias reviews. Real challenging stuff. Then find some marketing person to shout how wonderful it is - without even hearing it ???
Greg
Old 27th December 2005, 05:16 AM   #47
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Home sweet home
What is the V/DIV on your picture Greg? Without it seems difficult to ***** the result!
5V/div??
\Jens
Old 27th December 2005, 05:41 AM   #48
Account Disabled
Hi Jens,
When I cropped the photo I left in the V/div selector. 1V /div.
It's roughly 1W. The sq wave gen's just a lashup at present. Needs a box, connectors and a pot for functionality.
greg
Old 27th December 2005, 06:00 AM   #49
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by JensRasmussen
Home sweet home
5V/div??
Jens, you can actually see the knob at 1 V/div. Check the black stripe on the knob.
Greg,
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 27th December 2005, 07:46 AM   #50
Originally posted by amplifierguru
Hi Jens,
greg
I know, I was unsure about the x5 botton......
I often use a x10 probe, I thought that you might do the same
How about a rail to rail pic?
\Jens
The modulated supply and voltage swing (patent #5,343,166) rtarbell Pass Labs 13 25th April 2006 02:50 AM
Modulated cascode and positive feedback? Circlomanen Pass Labs 4 13th March 2006 01:14 PM
Direct Coupling Modulated Bias (SET) serengetiplains Tubes / Valves 59 10th February 2005 08:28 PM
MODULATED lobing and response Bill Fitzpatrick Multi-Way 43 2nd March 2004 10:58 AM
resistor vs. fet single, or cascode opamp bias? crippledchicken Parts 0 20th December 2003 07:26 PM
Copyright ©1999-2017 diyAudio
