Old 10th November 2005, 09:23 AM   #1
Default Headphones and damping factor?
I have tried to search for info on whether damping factor matters for headphones, and, not surprisingly, found contradictory answers. On this forum I found some claims that it does matter. Somebody said that Sennheiser design their headphones assuming a zero-Ohm output impedance. Somebody referred to somebody elses measurements, but the link was unfortunately dead. On the other hand, according to this link
http://www.epanorama.net/circuits/he...ttenuator.html
there is an IEC standard that headphone outputs should have 120 Ohm output impedance (or do I misunderstand?), so then most headphone manufacturers ought to design for that, one thinks. It is also claimed that damping factor anyway shouldn't matter for correctly designed headphones. So what should one make of this?
The reason I was wondering is that a very common and practical way to implement headphone protection is to have an output series resistance and a relay that can short the output to ground via this resistor. For practical reasons one doesn't want a too small resistor. However, the epanorama link additionally raises the question whether one even should have a 120 Ohm resistor on the output?
Old 10th November 2005, 09:29 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Christer,
The guy inn the link sounds like he knows what he is talking about. If indeed phones are NOT mass controlled but resistance controlled, damping would be a non-issue. That would mean output driving Z is a non issue.
The 120 ohms appears to be selected to be about right for different types, but not a specific value for acooustic reasons, so you would be at liberty to vary it depending on your needs.
Maybe you could do a quick check of the IEC pub, if you have access to it?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 10th November 2005, 09:31 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
Damping factor has some influence. Check this . As you can see the frequency response gets not flat, more like a boost in the base.
I have also listened with 120 ohms out and 10 ohms out and the difference is huge may the golden ears say but I'll find it microscopical, almost zero in fact. I used 150 ohms Sennheiser HD545.
Christer if you have 100-120 ohms out you will get both short circuit protection aslo attentuation if you use low-Z cans.
/Per-Anders (my first name) or P-A as my friends call me
Old 10th November 2005, 09:37 AM   #4
But Per-Anders, that seems to be a measurement of the amplifier under different load conditions. I want to know how and if the headphones are affected by the output impedance. Designing the amplifier to handle different load is important, but a different issue.
Old 10th November 2005, 09:40 AM   #5
peranders's Avatar
The only thing you can see from measurements is that the voltage is increased a bit in the bass. Is the headphone affected? Don't know, I'll just listen in this case.
Old 10th November 2005, 09:43 AM   #6
00940 is offline 00940  Belgium
According to Jan Meier, the output impedance matters.
For the maths, see here : http://www.meier-audio.homepage.t-on...tipstricks.htm
Ben.
Old 10th November 2005, 09:46 AM   #7
How can you see that? The headphones are only connected in one case. There are no curves for headphones and different output impedance. Besides, I am interested in a more general answer, if possible, not only what happens to one particular pair of headphones.
Jan,
Yes, the guy at epanorama certainly sounds like he knows what he is talking about. On the other hand, there are many people who sound like that without actually knowing. However, he has the IEC standard to back it up, so the question the would be if headphone manufacturers bother about that standard?
Old 10th November 2005, 09:55 AM   #8
Thanks, I think that is the same person that was referred to in the link that was broken. It is obvious of course that output impedance matters if the headpone impedance is more than marginally dependent on frequency, and it seems from this article that that is usually the case. Interestingly, he also refers to the 120 Ohm standard, but seems to indicate that most, but not all, headphones sound better with a lower output impedance. However, he seems not to discuss anything lower than 50 Ohms, so maybe that is safely low? I guess the sensmorale of what Meier says is that a headphone amp should ideally have a choice between different outpur impedances (series resistors, that is).
Old 10th November 2005, 11:14 AM   #9
janneman's Avatar
Christer,
I must say that Jan Meier doesn't really give any arguments why the phone imp would be freq deopendent. The story of break in also detracts from his credibility.
The measurements shown above certainly do NOT agree with him. They seem to indicate that only minor changes result from different damping (different Zout). There is SOME effect, but orders of magnitude less than with speakers. So, my vote goes to the first guy.
Jan Didden
Old 10th November 2005, 11:23 AM   #10
peranders's Avatar
Compare the soundcard itself, with resistive load and with complex load. With complex you will not get a flat response. I have also tested with 120 ohms out and the difference is minor compared to 10 ohms.
Christer
Build a CMOY or similar and connect a trimpot in series and test different values. You will be surprised how little difference it makes. When you have done that yopu can also compare what Dr Meier says. Are small things big or are they small?
Damping factor in DIY amp jaya000 Solid State 25 25th September 2008 11:27 AM
What is SI T-Amp DF (damping factor)? skrstic Class D 1 23rd April 2008 09:49 PM
Damping factor Cro maniac Chip Amps 29 8th May 2004 01:16 PM
Damping factor thylantyr Solid State 9 14th March 2003 06:37 AM
Damping factor..????? emarald Solid State 15 30th January 2003 02:41 PM
Page generated in 0.12457 seconds (84.66% PHP - 15.34% MySQL) with 10 queries
